Working Kapanadze Generator Circuit!
Started by worldcup, November 27, 2022, 09:47:02 AM
pix
Quote from: Boja on February 11, 2023, 01:07:20 PM
So it easily ignites 2 direct incandescent lamps of 500 watts each, and can ignite the same amount in parallel ..
and, your 300 watts are - unsuitable!
Initially I was very interested on Bunk's device and spent a few days translating every russian forum he was active on.
Watch every of his video, some made me suspicious as he didn't show back of his hand ( cable running through sleeve), not lifting up his device completely or holes in the table where he was presenting his device running. This started a warning lights in my head.
It is very easy to hide in his "box" a mini inverter.
So far nobody can give other explanation on Bunk's principle.
Also, you can see a big difference between his first and last devices.
Regarding "500W" incadescent lamp- you can't judge actual power without measuring voltage and amps, plus you could light it with high frequency high voltage power supply.
(8) how to make simple inverter 12v To 220v , 3000W - YouTube
ramset
Boja
Here administrator strongly discourages flamewars !
Also there are many persons with build experience
To build and test .... And share results!
Let results guide the path ...
IMO
It is strongly advised for readers to respect builder community
And allow replication for discussion ( and hopefully improvements )
However
The stage is yours ....( respect your wishes
Respectfully
Chet K
Ps
There are moderated build sections here ( where "you" can manage and present info
And moderate off topic to keep focus on builders and results!
Towards a goal of sharing the replication!
Thanks Grandma
Boja
Quote from: pix on February 11, 2023, 01:38:43 PM
Well, he will remove the lamps!
What do you wont on!? - kettle; hair dryer, or whatever you want...
I will pass on all your needs!
r2fpl
Quote from: Boja on February 11, 2023, 01:14:11 PM
Forum Bunk is up and running right now!
Your information is far from correct.
3 video from September 2022, already presented by me
They can be considered almost - fresh!
The Bunk forum was deleted many times by Bunk himself when he was asked inconvenient questions.
This is the original Bunk site. What is this ? nothing ! BS.
https://hhobro.forum2x2.ru/t1-topic
pix
Quote from: Boja on February 11, 2023, 01:51:03 PM
I saw already a boiling keetle video.
Problem is- he didn't lift up that keetle together with base during presentation.
Latest video: [size=78%]Озеро_15.09.2022.mp4 - Dysk Google[/size]
Again, he didn't lift it up during working. Plus- it is only 18 seconds presentation with bulbs working. Small battery pack with mini inverter will do such presentation.
So, as you see there is always something "fishy" that leaves a doubts.
