Working Kapanadze Generator Circuit!
Started by worldcup, November 27, 2022, 09:47:02 AM
worldcup
Fuel-free generator 1 kW
PDF attached, any thoughts on this ?
got from ES / russian forum, password protection removed.
pix
Russian forum...
Still can't see any mechanism responsible for energy gain.
endlessoceans
Quote from: pix on March 08, 2023, 06:46:14 AM
Russian forum...
Totally agree
If the waveform shown is the output, theres absoloutelu no gain there
A
Dog-One
Quote from: worldcup on March 08, 2023, 03:44:34 AM
Pretty detailed, but I suspect much of it is misleading, especially the
principal of operation.  Certainly don't buy the whole copper isotope
AMR, surface spin wave stuff.
The only possible gain mechanism I see is the toroid core.  This could
be a parametric resonance configuration.
I've seen that at least twice before when a toroidal shaped magnetic
core is wrapped normal and wrapped in a way that would restrict its
inductance.  The idea here is the winding that would restrict inductance
is oscillated at 2X the frequency of the main winding.  This causes a
pumping action in the main LC tank circuit.  To be overunity, it is
required the pumping action consume less energy than harvested
in the main LC.  To do this, you first have to establish a pretty high
energy flow within the main LC so that the exponential gain you get
per cycle exceeds what is required by the pumping excitation, which
is typically a fixed quantity.  From my testing, it is very difficult to
get a high enough Q factor to do this.  You would need an LC setup
that would ring 40 or more cycles from an impulse while only losing
50% of its amplitude.  Something with that high of a Q factor is
extremely tight on its frequency, so when you start pumping its
parameters, just a slight change in frequency and it quits oscillating.
To credit the writer of that PDF, the Figure 4 push-pull circuit using
a SG3525 chip does work really well.  I've built several of those
circuits and they do the job nicely.  The only problem using them
in the basic form without snubbers is that you must have a proper
load connected at all times, otherwise you blow stuff up.
pix
Reminds me kind of  Zatsarinin transformer.
Tried it, no any "extra" energy from it.
All that fancy coiled coils and "resonances" per se will not create excess energy.I see only two ways of getting "extra" energy:
1.Harnessing power of atoms, fusion, fission, induced atoms transmutations ect.
2. Capturing it from enviroment, similiar like photovoltaic cell converts sun rays to electricity, wind turbine captures wind  or a heat pump captures latent heat from the atmosphere.
In electromagnetic field a  heat pump analogy would be converting high frequency low amplitude/energy electromagnetic waves that are around us into low frequency high amplitude wave.
This could be done "Tesla Magnifier" style, by use of helical resonator.
In such helical resonator tuned to certain frequency, wave having that frequency doubles in amplitude during each period, and resultant  energy accumulation rises at amplitude squared tempo.
Resonator plays  a heat pump compressor role.
"Compresses" large amount of freely available low grade electromagnetic energy into smaller pack of high grade energy.
Converting high frequency high voltage into lower voltage useable current?
Electric discharge, spark gap.
There we have electrons multiplication by the expense of electric field.
We need to know mechanism and the source from where we might get energy.
Cheers,
Pix
