High Efficiency Lamp Driver
Started by joellagace, January 24, 2023, 05:35:53 PM
joellagace
Hello folks I wanted to share this with you all. I think it works great, thanks!
This method allows to run a 15 watt lamp with just an input drive of 60 hertz 40ma.
https://youtu.be/pr4t4JKPkYM
We can't make energy out of nothing. With that said we can find methods to use very little input source so we don't have to put in  much work or money wise to get operating. This lamp driver does just this.
I use a current reactive limiter on the mains 60 hertz power line or any other source of 60 hertz 110 volts power, Your generator, Your windmill etc....
The current limiter as per ohms law x= 1/2*3.14fc
I = v/x
So 60 hertz with around 1uf gives us about 40 ma of current only!
We use the mostly pure voltage to quickly charge a 10uf or more capacitor. With very little current input. The capacitor has an SCR diode that is triggered to dump this cap into an additional super capacitor bank a few times a second we get a pure 100 volt capacitive joule or amps per second discharge. This pumping also has an electret like effect while being pulsed as such. An additional advantage of also using a super capacitor bank is the elimination of the high impedance battery charging stage needing more current.
So basically the 12 volt super capacitor bank takes this form of converted negative energy from the reactance box and capacitor high voltage pules. back into a form of regular low voltage higher current DC positive energy  that is able to drive a very small very high efficiency high frequency AC inverter.
This inverter drives a 15 watt lamp no problem  because its high frequency. The 15 watt lamp operates at full spec lumens usually requiring an input of 15 watts. We are driving it with only an input that we need to pay for of 40ma.
The rest of the needed input is being provided by the local vacuum. And clever circuitry. Not a trick or a cheat for free energy bypass of the electric "smart" meter.  . The whole circuit except respectfully, the super capacitor stage. operates as an open looped system so it can re gauge itself.
Not only does the lamp operate at full capacity in this fashion. The voltage keeps rising on the super capacitor bank as it keeps getting many discharges of 100 volts a second from that 10+ uf capacitor dump simultaneously.  I'm actually needing to load this more with some time as the super capacitor bank can only handle around 13.5 volts. As you see from the meter the charge holds and even goes up instead of down as the super caps do a super job at converting this kind of power back into something useful!
I must point out that this lamp would not operate directly connected to the reactance X output of only 40ma! It requires 15 watts of input current at 60 hertz. We are not providing anything close to this level with this intentional current limiter stage. But at the end we are able to light bright and sustain the system with very little input drive from the operator work wise or money wise. No free lunch. Just efficient.
Dog-One
Quote from: joellagace on January 24, 2023, 05:35:53 PM
Pretty neat Joel!
Would you mind scratching out a basic schematic for those that may want to replicate your results?  Something that can be printed on paper for a later time should Internet access become limited.
As energy costs continue to increase, I have a hunch many folks would like to cobble together this circuit of yours with parts they may have laying around.
Thanks much for your effort and sharing what you have accomplished.
joellagace
Sure I have it on my youtube. It's called "Free Energy Generation Using The Electric Company"
https://www.youtube.com/watch?v=fVMpQQugA-0
This is the big part and important circuit. Simple but critical. The X factor reactive box that drops the current usage from the 60 hertz 110 volts to just 40ma. A kind of current gate or limiter so to speak without wasting any energy needing to pay for heating resistance to "drop" a load.  The key is to not have to use or use very little current to achieve interesting results.
For this demo the only thing I changed is instead of charging a set of batteries, Those got eliminated and replaced by a 12 volt super capacitor bank. (more efficient storage) This bank simply runs one of those ebay cheep Chinese high frequency inverters feeding the 15 watt lamp.
citfta
Hi Joelagace,
It's nice to see a new member on the forums.  Your circuit is interesting but as was explained to you on OUR it is not a good idea.  That circuit would be severely frowned upon by the electric utility and probably illegal in many places.  What your circuit does is introduce a strongly reactive component back into the power grid.  All commercial appliances are tested to make sure they do NOT add a strongly reactive component back into the power grid.  Granted if only you were using this circuit they would probably not even notice the reactive component.   But if enough devices like yours were connected to the grid it could cause problems for the generating plant as reactive components can cause very high voltages to appear at the generating source.  By posting this circuit you are putting yourself in a position to have legal action taken against you and or any forum you post it on.
Respectfully,
Carroll
joellagace
If your so worried about the electric company and I also note this, use your own source of AC. A windmill a generator ,solar inverter. Go nuts. I'm all about the research and this circuit does not bother me for legal issues. I guess if your that worried about it complain to youtube and facebook and everywhere else its hosted now?
I'm really getting annoyed with the OUR forums. Seems like when you get to a level with this kind of research people just no longer understand once you mature to a certain level, I was about to say my farewell to the OUR group anyways. It was short lived and the folks out there really didn't get it from a  research stand point. Again I know at lease basic ohms law.
Take care and enjoy my circuits!
