100 watts output with 60ma input
Started by joellagace, February 03, 2023, 05:28:31 PM
joellagace
Thought I'd share this here. Here is my video of my latest device with Back EMF charging.
Runs an old school 100 watts 60 hertz AC bulb from the inverter, Battery holds and charges up at the same time from Back EMF cap dump. The back EMF stage controller only needing 9 volts DC 60 ma input to operate and produces hundreds of volts of BackEMF collecting charging a capacitor that dumps this into the battery 2 times a second at 100 volts.
https://youtu.be/QYpwTJJ3lh8
I fixed up my 9 volts dc 60 ma radiant trigger back emf and 100 volts cap charge and dump circuit controller and generator by taking away much of the high impedance test lead clips and replaced with  short thick wires. Especially for the back emf coil and cap dump stage. In a previous video. A more sloppy version of this I was able to run and maintain a 15-20 watt load from the charging battery without the v/i curve going down, It was going up!
With this improved setup, It now appears, I'm now able to do the same thing with holding a real 100 watts load on the battery while charging it with the radiant cap dump device at the same time . Heavy emphasis the whole input stage only needing 9 volts dc 60ma from a wall transformer power supply. This is my small input trigger requirement. That is it. The rest of the energy as Bedini would say comes from the Vacuum or Negative Energy. The battery reacts to these steady voltage discharges from the capacitor and transduces this pulse into real steady current of 100 watts while maintaining a v/i curve or charging curve instead of a decline curve as one would expect while running a 100 watt load for 15 minutes. A kind of negative resistor.
This video is a little longer, Its about 15 mins. I wanted to show you start to finish what goes on, Very similar to the "kromrey generator" At first start the battery shows a slight voltage drop of a few points, after 2 minutes the v/i curve stabilizes and soon starts to raise steady as long as the battery keeps getting that high voltage cap dump pulse 2 times a second all while maintaining a 100 watt load. I can hear a kind of boil sound when I put my ear next to the battery so it must be doing something! This setup holds the big 100 watt load without the v/i curve going continuously down, after about 15 min run time in this video, you really see the increase of voltage by many points in comparison to the start of this demonstration as the v/i curve goes (charges) up. Sorry for the length. It takes this much time to show you without editing the video what is happening. It runs the opposite! This is an awesome COP value. 9 volts 60ma input and 110 volts 100 watts 60 hertz output. Or more if you want to take the inverter power consumption as well into consideration and all other losses.
NickZ
   Then why don't you do a real test, like for a day or two? As 15 minutes test runs are not very conclusive. To see if your 9v DC battery charger is really charging the bigger car battery, or not. Volts are going up, while amps may be dropping. A longer test run will show if that is what is really happening, instead.
  NickZ
joellagace
I did just this, I know it works all day. I did several tests with this. But yeah I admit I'm not a lab or anything. Many would argue that cutting even random lengths of what ever thickest wire I have around and just whipping something together  as "scientific" I get it and just hope to inspire and share what I know. It may not be very useful to some on these forums I get it.  But I'm sure for some others this might be the information they are looking for.
As far as making more videos I don't think your suggesting that I record this for 2 or more days and publish as a video just to prove it works? I already know it works. I'm sure the folks can take the information or leave it. Modify it replicate it, make it better in anyway anyone wishes from this point on.
We are not all pros and experts in the field of free energy here. As much as some members here may feel they are indeed.  This is a community forum. We are all amateurs and hobbyists of varying levels. As for the ones who have figured out real marketable free energy devices are already racking up the cash, Has patents etc.. sitting in an executive possession and I can guarantee you is not hanging out in these forums, The others that have any process that could be considered a threat to the status quo end up being censored. And make a deal with the government.
I'm not targeting the last post specifically, I just feel from the general vibe I been getting in these forums from the last close to 10 years I been a member here. Not all but a big part of the replies are naysayers (same member names I notice doing this in many posts from random users as well) that are being as arrogant as welcoming me to the forums as a new user lmao. I been here for years posting... And the naysayers are basing their rational on their own expert knowledge. Of apparently being a bunch of highly educated expert specialists in the FE field, insinuating I don't understand etc.  So ....Instead of sitting behind a device trying to sound like the smartest bunch why not come up with the video's yourself and publish your findings and help us amateurs out? If the naysayer groups of folks don't want to help, why try and discourage others that may want to research and experiment with similar methods?
A lot of this seems to be "I don't agree/understand it personally, so fake news"
Just pondering.  8)
Goat
Hi Joel;
I just watched your video and find it (As Spock would say) Fascinating!!!
I have messed around with Bedini and other circuits over the years but never could manage to get the battery to maintain let alone recharge like your setup is showing.
Please could you post a schematic of your setup so that we could attempt to replicate your findings, I'm especially interested in your cap dump setup.
Thanks for sharing.
NickZ
  Ok well, all I asked for was for a longer run time. You can do overnight test runs, or all day runs. Short videos of the time started, and time ended. As we have not seen it doing so, it would help to convince us that your device can self run, all day all night,  etc ...   As THAT we have never seen.
   NickZ
