Mosfet Capacitor Dump Experiments
Started by SkyWatcher123, February 08, 2023, 06:03:00 PM
ovun987
Quote from: joellagace on February 17, 2023, 06:12:04 PM
Thanks, This gives me good ideas on what I might want to try next, Still waiting on some ebay sales in order to get more money to buy those mosfets. And other parts  ;D
What exact parts do you want to buy?
Link to what you're wanting and some of us will get you what you need
I appreciate your line of experimentation and want to encourage your progress
joellagace
Well here goes for those who are interested and following  ;D I'm not lying about the ebay sales thing to make it sound good, If anyone of you are into ham radio stuff send me a private message, You might like what I have for sale, I'm not going to start listing my sales on these forums as the topic is not appropriate here., So just send me a private if you like,. So yeah what I'm looking for on my list:
(2)ISD1820 Voice Recording Recorder Playback Module https://www.aliexpress.com/item/4000117283510.html?spm=a2g0o.ppclist.product.36.785eN8NxN8Nxnz&pdp_npi=2%40dis%21USD%21US%20%242.78%21%241.89%21%21%21%21%21%402101d1bb16719949476468476e2570%2110000000309510908%21btf&_t=pvid%3A1b580833-92fd-4682-8a1b-363304d68076&afTraceInfo=4000117283510__pc__pcBridgePPC__xxxxxx__1671994947&gatewayAdapt=4itemAdapt
I want to experiment with recording my custom waveform frequencies into this chip, saving it and playing it back on loop mode, instead of a speaker it drives a transistor or mosfet. As a switch. I could make something with a 555 or similar but with the Parkinsons my hands shake too much for working with little circuit boards and a solder station. So this is my quick work around instead of using a tablet or cell phones sound output.
(5)BTA40-700B BTA40 High Power Bidirectional Thyristor   https://www.aliexpress.com/item/1005004108996863.html?spm=a2g0o.productlist.main.27.3a3b4000yGugDj&algo_pvid=1696398a-e071-4ddc-9c92-12f8a895d932&algo_exp_id=1696398a-e071-4ddc-9c92-12f8a895d932-13&pdp_ext_f=%7B%22sku_id%22%3A%2212000028061037277%22%7D&pdp_npi=3%40dis%21CAD%211.68%211.6%21%21%21%21%21%40211bd8be16767031249093072d0763%2112000028061037277%21sea%21CA%210&curPageLogUid=lEshdGQVccRP
Some high power Triacs. Hopefully these wont pop as much with the cap dumps.
(2) https://www.ebay.com/itm/144130345062?var=443434748235
Simple low voltage Square wave generator module. I use these in my various switching circuits. Saves me from having to build my own module for this feature.
(2) Neon bulb ne-2h 6x18 https://www.aliexpress.com/item/32346512958.html?spm=a2g0o.productlist.main.31.55b4796aqUgn3c&algo_pvid=dbbfaf1e-d755-4635-ab34-88ddaf662ce6&algo_exp_id=dbbfaf1e-d755-4635-ab34-88ddaf662ce6-15&pdp_ext_f=%7B%22sku_id%22%3A%2251666719826%22%7D&pdp_npi=3%40dis%21CAD%213.17%213.17%21%21%21%21%21%4021021d7b16767037183641096d074c%2151666719826%21sea%21CA%210&curPageLogUid=V7D3F3kL2Mx7
Neon lamps for various triggers.
(2) 1N5362B (5W 28V) https://www.aliexpress.com/item/32828310431.html?spm=a2g0o.productlist.main.1.106c6eddcB37sD&algo_pvid=998880a6-b3a0-4bc3-af54-5935b445fffc&algo_exp_id=998880a6-b3a0-4bc3-af54-5935b445fffc-0&pdp_ext_f=%7B%22sku_id%22%3A%2265010561482%22%7D&pdp_npi=3%40dis%21CAD%213.89%213.7%21%21%21%21%21%40211be59e16767040827416663d0736%2165010561482%21sea%21CA%210&curPageLogUid=uiG4THde2zMC
Zener didoes I would like to experiment with to replace those neon triggers.
-various high power mosfets and transistors. Various values, I been given many examples from recommendations.  Vast options and generics here. some folks may already have a "junk" stash laying around! So if someone where to donate me any of these I'd take what ever as I can most likely use it as long as it handles high power so no little 2N2222A hehe.
-Conductive paint. Lots of it. Enough to paint thousands of sheets of paper to build my high voltage cells that will feed a spark gap/cap dump assembly and charge batteries,  Stick foil on the other side.
So I understand this is a long list. I don't expect anyone to get me any of this. Just that it's been asked a few times now so here it is.
Thanks for the info. links are just examples. I'm sure there are better sources out there!
joellagace
Some help that someone may be able to help me with, I'm trying to extend the cap dump method without needing an inverter if I want to "self" operate. Right now if you eliminate the inverter you can't get the back end to charge to front end, the inverter acts as the isolator between the two as well. It's just the inverter takes a few watts of idle power from the internal circuitry and what not. I would like to eliminate that extra load if I could find a better way to isolate the two? any ideas?
John Bedini used opto-isolators As I can see I'm just not sure how I'd incorporate that with my existing circuits, Just pondering. Since we are talking about cap dumps.
Thaelin
  Have you considered boost converters. There is a fully isolated version. Bit spendy and have different voltage out settings.
thay
joellagace
Thanks for the info, I have a few of those modules near by, Never thought of taking advantage of the isolating feature of the boost converter, I will look into that for sure.
Why I'm so anal over the cap dump method is simply because a video from dr peter Lindemann on Aaron Murakami book site states that john Bedini was only able to get perpetual motion or near if you want to consider years of operation from the same battery bank. Was using cap dump methods, He admits on the site from one of the conference video's that John was only able to produce these effects with cap dumps, But later on when it came to charging a separate industrial battery bank of like 48 volts, It was much better to use the radiant directly. But this was not a setup for "Self running" Just charging an isolated bank.  It seems from the various insinuations around John did that way back in the day with the original gravity wheel and got "bored", As in the perpetual stuff. Personally I think the idea of a motor self operating and able to do moderate work at the same time (the cromley or how ever its spelt motor) for example is a better deal for the general user, Where you have this thing that self runs and you get to use a few watts to drive a small lamp without draining the battery etc.. vs trying to charge industrial 48 volt banks. Not everyone has that setup or is it practical or portable for real world use. I wonder why john stepped away from what I think is the much better achievements.
