The basic requirements to obtain free electricity.
Started by Cadman, February 10, 2023, 07:28:38 AM
forest
Tesla coil + antenna + modulation of charges + induction = free electricity
typedusud
A field effect transistor is an advance transistor, use to amplify energy and oscilate ( replace efficiency the spark gap used by N tesla)
A ferrite is a load to modulate energy
A cold coil, or caducee coil is an energy generator like the ring of the eart that are in clockwise and counter-clockwise among them
A resistor for determination of energy production, the smaller resistor, the bigger energy is produce
A capacitor for resonnating the system
An organic accumulator for harvest electricity , tesla use the earth itself
A lamp to generate the electric flow .
The coil must be cooling because he become very hot at 8 ampere, can be multiple coil or a supraconductor coil.
With 100 watts amplifier the output energy is hight enought to replace all earth power installation, like Tesla said.
The cooling installation cannot be done by yourself, tesla use a huge dome for it.
It is like the tesla tower, energy unlimited but you know the story...
And if you use battery, with a "free energy system" the will be dead in fews hours if you
dosn't keep them in good conditions. It that why there is no free energy, but only efficients systems
    If you run a car WITHOUT amortissors ( coil, spring), you loose energy. So "Free energy systems" use coils ( spibg) to smooth the load in his electric "road".
The true problem is not technical, it is consciousness and spiritual.
Ufopolitics
Quote from: Cadman on February 10, 2023, 07:28:38 AM
What is it we really want here? Isn't it free electricity? Something with substantial volts and amps?
Start by paying attention to the pioneers. The experimenters, scientists and physicists in the past who 'discovered' and worked with electricity. There were no laws or definitions or even terminology for it back then. It was more like 'Hey, I have an idea. Let's try it and see what happens.' They invented the terminology to describe volts, amps, and magnetic fields. They didn't know what it was but they figured out how to work with it and use it using their own terminology.
At it's most fundamental level we still don't know what electricity is but we don't need to know that much detail. We only need to know the basics to get started.
What are the basics, the foundation to build upon?
Definition of a volt.
One volt is the potential difference between two points that will impart one joule of energy per coulomb of charge that passes through it. The pioneers thought of potential difference as tension.
Definition of an amp.
One ampere is equal to 1 coulomb or 6.241509074×1018 electrons worth of charge moving past a point in one second. So what's a coulomb?  6.241509074×1018 electrons.
Those two definitions tell you what needs to be done. You have to bring charges (coulombs/electrons) into the system and raise the tension on those charges to move them past a point in the circuit at the rate required to obtain the amperage you want. Nothing more, nothing less.
Anything that aids that goal is worth investigation. Anything that does not, is noise.
Edit: corrected 1018 to 1018
Hello Cadman,
I clearly understand what you are doing...trying to go to the "origins", the primitive discoveries of Electricity (by now, all forgotten)...like a "restart" from scratch.
Unfortunately, I do not think "this is all" we need, like you mention on last paragraph and bold out sentence by me.
Volts and Amps I always have look at it like this paradox, where Voltage are the Highways and Amps are all vehicles traveling and speeding up through...
Where many other factors, parameters (also very important, and can not be disregarded) that regulate such traffic of Electrons...for example: Resistance.
Imagine a constant speed through a 4 way highway of a "population of vehicles",(electrons), moving through...and all the sudden two of this ways are blocked, maybe an accident...so a restriction (resistance) comes in play...all vehicles most reduce its speed, and concentrate even more on only two roads, or half the normal Voltage was allowing...So, the "Amperage" (Population) had reduced in aprox 50% due to the traffic jammed which generated a higher resistance of flow...Amperage reduced do to a higher resistance.
However, I honestly believe the main reason why we have not reached yet, and here I would not even mention "overunity" or "free energy" not to bring unwanted responses...I would just say...a cleaner, non fuel dependent (of any type, including hydrogen plus non nuclear reaction methods) is basically due, not to not knowing what exactly electricity is...BUT, what is a Magnetic Field?.
For hundred of years, we have been totally ignorant of what is exactly a Magnetic Field...and so far, it is the only "agent" which we all have been depending upon, to obtain, generate, Electricity...except Nuclear Fusion or Chemical batteries.
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
forest
All we need is to find source of energy like ambient heat for heatpumps and the method of conversion to usable power.
