Serious HES derivative project proposal
Started by Cadman, February 11, 2023, 04:42:40 PM
bistander
Quote from: SolarLab on April 03, 2023, 12:11:53 PM
Bistander - nice work, curious as to how it will work out.
SL,
It works great as a core. I have no problems with it. Here I compared 4 coils (one per tooth) to coil surrounding the 4 teeth for induction using 60 Hz from variac excitating the original primary. I'll share after I figure a good way to present data. Been using Excel. I'm rusty at that.
bi
kolbacict
Quote from: bistander on April 03, 2023, 05:00:57 PM
SL,
bi
When will we finally get more active power at the output than we fed at the input ?
bistander
Quote from: kolbacict on April 04, 2023, 01:42:20 PM
I think you know.
bi
SolarLab
Cadman,
Before beefing-up the 30 Ton press I'm going to follow your lead re: "resin & iron powder mix."
May have considerable merit IMHO - for example, see the attached paper.
SL
Quote from K - "Are you done yet, are you done yet?"  ;) Quote from SL - "Give it a rest!"  8)
Q.: If I thought for a second that this method didn't work, would I spend >$2800us on machines
to make and test laminations and substrates?
