Serious HES derivative project proposal
Started by Cadman, February 11, 2023, 04:42:40 PM
bistander
Quote from: kolbacict on April 06, 2023, 03:16:49 PM
Not. stator have 36,rotor 24.
36, 24 sounds like # of teeth (or slots), not magnetic poles, which are typically 2-pole, 4-pole, 6, but seldom much if any higher on that size. The point is, running, for example, a 2-pole member with a 4-pole member may cancel induction between the two. It's easy to tell pole count if the machine used a salient pole field, like 2 or 4 PMs. If it is a distributed wound machine, like induction motor, you can determine the coil pitch (radial distance between coil sides).
bi
kolbacict
Quote from: bistander on April 06, 2023, 03:38:32 PM
I have understood now. I think that the number of poles can definit from that, motor have 1380 rpm. on 50 hz.
And the little motor have one phase, 50hz. and 800 rpm.
The output frequency does not increase or decrease compared to the input.
Only when the rotor is rotated inside by hand, does the phase change relative to the stator current.
rakarskiy
Have you inserted the motor stator into the motor stator and wanted to start the system?
See the hint, you need to simulate the operation of a permanent magnet magnetic rotor. Where did you see a permanent magnet working on a sinusoid?
The second clue in the generator is the magnetic field from the phase current and the magnetic field of the rotor must be summed up, it is this moment that forms the electromagnetic braking force.
I already wrote here that a good motor is a useless generator, and a good generator is a useless engine.
kolbacict
Quote from: rakarskiy on April 07, 2023, 03:20:08 AM
Yes, I want it very much.
https://youtube.com/shorts/C6SMwxh-Mvw?feature=share
kolbacict
Why my copper foil or pipe  placed into stator with current. And my pipe isn't making short circuit for stator's windings ?
The foil should create one short-circuited turn for the stator windings.
But however this copper foil placing between stator and my yesterday rotor decreased its induction a bit.
