Serious HES derivative project proposal
Started by Cadman, February 11, 2023, 04:42:40 PM
skybiker63
A Synchronous homopolar Generator shows excactly all parts of a HES, the only changement is that the axle needs to be blocked and fixed.
This kind of Generator has coils instead of permanent magnets
It has an outer static stator with moving magnetic field which can be controled in the speed
It has an inner Rotor only by coils and only wiring needs to be changed.
Could this be not helpful ? By using this we do not need to construct any arduino, because everything is ready.  :o
What do you think ?
Jimboot
Quote from: rakarskiy on February 22, 2023, 03:10:51 AM
Got some information from a person (not public) who decided to reproduce Holcomb's patent in miniature. I gave him advice and my vision of how the generator works. The guy already has a control unit with software and the corresponding cores are machined. If I have more information about the results of this experiment, I will definitely inform you. The guy follows the usual logic and I like it.
Sincerely yours.
A small photo collage
Thanks mate. Is your book still coming? Are they photos of his work? Love to know more about his cores. That is the biggest barrier for open source builders atm I think.
Jimboot
Quote from: Cadman on February 21, 2023, 12:22:43 PM
The prints fit well, no mods needed.
It takes an hour and 10 minutes to print one. 5 down and 31 more to go.  :o
Also picked up a couple more motors off Ebay today.
Are you guys starting to believe I'm serious yet?
Have a good day everyone.
Because of your work it was so hard to drive past an F&P washing machine left for recycle, my wife was with me though and I already have to many rotors and stators. :) Thanks for sharing your progress.
Cadman
Quote from: skybiker63 on February 22, 2023, 04:23:08 AM
What do you think ?
Hi
This has already been discussed at length in the other threads. It will generate, no doubt about it but there's no need to continue the discussion here, at least not yet. I would love to have a self sustaining 3 phase output but the time for debate is over, it's time to build.
Cadman
Quote from: Jimboot on February 22, 2023, 04:29:15 AM
Hi Jimboot,
Wouldn't it be grand if we all had the resources to build something like rakarskiy showed?  I'm with you, the steel laminates are the biggest barrier.
If this project succeeds then I think the same methods may work with generator heads and even automotive alternators too.
Speaking of laminates, while holding the stacked laminate forms in my hand and looking at them, I thought of a better and easier way to make the core. I stopped the printing for now while I explore this new method a little more.
QuoteBecause of your work it was so hard to drive past an F&P washing machine left for recycle, my wife was with me though and I already have to many rotors and stators. :) Thanks for sharing your progress.
I'm kind of envious. Where I live we're not allowed to set appliances like that out for recycle pick up. If we were I would probably turn into a hoarder and my house into a scrap yard.  :)
Cheers everyone
