Mechanical resonant oscillation as basic overunity method
Started by nix85, February 17, 2023, 06:54:53 PM
perpetual
As an example that my ideas get proven as overunity, 3 years ago i proposed this idea
"I had this idea to pulse high inductance coil with short square pulse, so short virtually no current gets through the coil and then collect the backEMF that develops across the coil."
https://overunity.com/7837/magnetic-resonance-devices-based-on-don-smith-concepts/msg551080/#msg551080
At the time i had no idea that exact principle was already proven as overunity in 2017. by Tanju Argun. He is doing various stuff here but main thing i refer to is, quote from video description
"In 1993 Tom Bearden came up with the idea of "Massless Displacement Current". I was inspired by that.
As you might know there is a process called "The Skin Effect" where Electrons, before forming a current, must travel from the center of a conductor to the peripheric rim to travel. The time, the electrons traverse from center to the rim is called the" Relaxation Time". We are talking Microseconds here.
So, what I am simply doing here is, just letting a big Capacitor to sniff the Potential of a 24 volts Battery for only 100 Microseconds. During these 100 microseconds, electrons start to move to outside perimeter of the conductor to start the current. But unfortunate for them time is not enough to form the current.  Instead those trapped electrons just attain a "Potential Gradient "across them. So, the capacitor gets the Potential Difference across it with minimum current, which is called the "Massless Displacement Current".
In analogy; the young man "the capacitor", just catches -a glimpse of a passing by super-mini skirted young lady- "the battery".
Capacitor is loaded with minimum power.
Ideal case is to use iron wire or doped conductors and plates to block the electrons from forming a current by increasing the "Relaxation Time".
After 100 microseconds, the Mosfet switch (Blue) opens and disconnects the battery from the capacitor.
Another Mosfet switch (Yellow) closes and connects the loaded capacitor to the load for just 1 millisecond (In our case the load is the Bedini wheels and Coils).
After that millisecond when both Blue and Yellow switches open, this time the Red mosfet switch connects the charger to the battery when nothing else is connected. Red switch connection time is adjustable.
All these timing operations and void loop is controlled by an Arduino Uno micro-computer composed of a simple sketch of time delays."
https://www.youtube.com/watch?v=70_xKJh91eE
Nix
