Magnetic flux motor just patented that creates it's own electricity!
Started by am1ll3r, March 02, 2023, 07:32:40 PM
kolbacict
It reminds me mechanism secondary clock.
If you remove the coil and rotate the stator itself.
There, too, interaction occurs in shocks.
SolarLab
 Let me correct, or clarify, my previous post where I state:
"You slightly disrupt the "completed" magnetic field by raising one side of the magnet, thus allowing the magnet to be easily lifted free of the plate."
This should read:
"You slightly disrupt the "completed" magnetic circuit by raising one side of the magnet, thus allowing the magnet to be easily lifted free of the plate.
My appologies!
hartiberlin
I translates the German PDF File from Adolf Schneider with
Google Translator and here is the ENglish PDF File to download:
stivep
Stefan  please get a copy of:
Study of cogging torque in surface-mounted permanent magnet motors with energy method.
https://www.sciencedirect.com/science/article/abs/pii/S030488530300324X
Quotecogging torque in permanent magnet motors with skewed rotors,
Quotemethod for analytically predicting the cogging torque and provide a convenient tool for the analysis of cogging torque.
The study assumes that the airgap permeance repeats from tooth to tooth periodically.
Then the expression of coenergy in airgap is obtained after the Fourier expansions of magnetization and airgap permeance.
The validity and correctness are verified by calculated results obtained from FEM.
Finally, the effects of some factors on cogging torque are discussed on the basis of the above, and several conclusions are drawn.
At the bottom  of the  article you have all other  links  you need.
Wesley
ramset
Stefan
Thanks for providing the  "analysis of claim" translation from borderlands link
Seems Large COP gains and discussion of methods used .
Sending out to various open source resources to hopefully start a path towards a meeting!
Or see if there has been any actual visits to facility from independent investigators ?
Respectfully
Chet K
Thanks Grandma
