Magnetic flux motor just patented that creates it's own electricity!
Started by am1ll3r, March 02, 2023, 07:32:40 PM
stivep
We know now what motor it is
I found   speed control used in the assembly.
PWM DC Motor Speed Controller
https://www.ebay.com
EDITED:speed control below is also made in other voltages  range
Features
Wide voltage from DC 7V to 70V , large current 30 Maximum
A switch with Run , Stop , Brake functions on the board
Adjust speed by PWM , motor has no noise and shock
Using high pressure MOS , There are three high voltage low resistance capacitors with 100V
A high quality car fuse onboard
This controller can be used for brush motor and fan such as:  power wheels , trolling motor , spray motor ,LED strip...etc...
Note: This controller is just for DC Brush motor , it can't be used for DC brushless motor and AC motor
ParameterInput voltage: DC 7-70V (70v is the maximum voltage, please live a margin)
Drive current: Maximum 30A (Please use within 30A)
Controlling power:  recommended within 12V 300W  / 24V 400W / 48V 450W / 70V 500WDuty cycle range: 1%-100%PWM frequency: 12KHz
Size: 85 * 59 * 34 mm / 3.34 * 2.32 * 1.33 inches
Please look at right  side  bottom of the picture in the video
here: https://youtu.be/_gGLN2LxwkY?t=182
Wesley
stivep
This is the motor it was used in the assembly.
Edited:
-these motors are in 12V or 90V depends from the model.
The  spec is here :
https://cdn.automationdirect.com/static/specs/ironhorsemtg.pdf
Speed control is  also made for different voltages so  matching type can be found.
The second picture shows exactly that  particular motor  compared to original pictures from video.
look at  the video and notice  two side screws  mounting motor.here:
https://youtu.be/_gGLN2LxwkY?t=115
Wesley
stivep
 Correction :
While examined  models matching inventor  motor  it was found that only
models marked in green color below correspond to the  that particular build.
When you go  to link :
please click on  the left on the model number  and compare it  with pictures.
Note: In the list   from link  you will not see Green  color.
I used  green color to mark motor  models  of that build!!!
These motors are made   on 12VDc  and 90V DC as well.
It was also found that  speed control as is shown  in previous comments
is also made  at 12V and  90V as well  although both look alike.
Driving motor  information is very important  in  evaluation of the device
along with spec of the motor,
Wesley
stivep
Please remember that here you have   measuring equipment and software used by inventor:
https://overunity.com/19405/magnetic-flux-motor-just-patented-that-creates-its-own-electricity/msg574918/#msg574918
That is important as:
inventor shows on exactly the same  set of  measuring devices that  he  achieved  more energy out than  en energy IN.
If physics this is impossible, non-doable, rejectable, and  nonsensus,
It could be, due to  lack of calibration or any other  error.
Wesley
bistander
Since he is using a bench power supply which likely has variable voltage with current limiting, I wondered he needed the PWM speed controller. I suspect that would facilitate an attempt to loop the system. He'd have to gear up the output RPM steeply but if the gains are anywhere near claims, gear losses wouldn't kill it.
bi
