Magnetic flux motor just patented that creates it's own electricity!
Started by am1ll3r, March 02, 2023, 07:32:40 PM
bistander
Quote from: r2fpl on March 22, 2023, 07:04:40 AM
The question is, is it supposed to work with or without a load? This is essential.
What is the point? Presumably in the video, Mike starts it without a load. At least there is approximately zero average torque on the input torque sensor however with rotation, so, to me, that is a no-load running condition. Then Mike says he applied pressure with the caliper imparting a load via the disc brake. This shows on both input and output torque sensors. That is a loaded running condition.
If without then the torque of inertia is fine as long as the revs aren't too high.
Sorry, but I don't understand you. Inertia of each moving component as well as on input and output, influence system behavior at each velocity change, which happens continually in a cogging system when it's rotating.
If with a load, for example with a coil, there will be no torque at all.
Again I don't understand. There are no coils.
Have you seen a magnet fall onto a solid block of copper? here is the answer.
Sure, I've seen that video. Also done it. Where is copper in this system?
bi
r2fpl
Quote from: bistander on March 22, 2023, 07:29:55 AM
Sorry, but I don't understand you. Inertia of each moving component as well as on input and output, influence system behavior at each velocity change, which happens practically continuously in a cogging system when it's rotating.
bi
I just don't see anything to increase power here. That's all.
Measurements may be incorrect because we do not know how the torque impulse affects the measurement. This is just an example.
If this device is to be useful, you need to find a use for it, because as a generator it is unlikely to work, but I can be wrong of course.
bistander
Quote from: r2fpl on March 22, 2023, 07:37:02 AM
I never said it was useful. I'm just trying to figure out why Mike says it is. I thank you for your help.
bi
r2fpl
Quote from: bistander on March 22, 2023, 07:50:03 AM
bi
Everyone has an opinion about it. I just saw a lot of devices where someone claims that it works but only works for him. Maybe there is something I don't see or understand.
:D
rakarskiy
https://www.motofluxpower.com/pudding/
https://www.motofluxpower.com/its-official/
In addition to the actual materials on the site and on their YouTube channel, is there any data from third-party observers?
