Magnetic flux motor just patented that creates it's own electricity!
Started by am1ll3r, March 02, 2023, 07:32:40 PM
lumen
@Brad
I hope your motor design in fact works out.
QuoteSo true super conducting wire has no resistance.
In order for a current to flow through a conductor, there must be a potential difference across that conductor.
So if super conducting wire has no resistance, and a potential difference cannot be had across that conductor, how does current flow through that conductor ?
A while back I did some superconductor research and was lucky enough to talk directly to a material science engineer designing superconducting ribbon.
There are a few ways one can energize a superconducing loop.
With a coil of superconductor they usually leave a short segment warmer and pump the coil with magnetic flux to cause current flow as they continue to lower the temperature of the warmer segment.
This works because the conductivity of the warmer segment fails under high current and works like a switch as it is continously made colder while pumping the coil with greater flux as it is cooled.
Another method is to supply current on each side of the warm section since superconductors are usually poor conductors when warm. Then quench the switch area.
Both methods will leave current flowing in a continous loop producing a huge magnetic field as long as it's kept cold.
It's all interesting stuff but still no sign of OU.
SolarLab
Quote from: tinman on August 30, 2023, 12:09:27 PM
Ok SolarLab. Are you really wanting to yield excess energy from magnetic fields ?
How dedicated are you ?
If you really want to get somewhere, you first have to ditch simulators, and conventional thinking.
Both these things are based around what they know-or think they know.
You need to build real world test setups.
If you are not a builder, then i cannot help you.
If you are a builder, and can show me some of your builds, then i can help you.
My self running motor dose not require any of these fancy parts that are no longer available, as we see in many of these !so called! self runners. Everything is off the shelf stuff, and even from the scrap yard.
No one has built a motor the same as mine, that pre-dates mine.
This motor is mine, and mine alone. It is my own design, and there is no other like it.
So, are you a builder with good building skills, or are you that guy that tries to get simulators and the likes to show you how it works ?
Brad
Brad,
It's already been proven you can achieve "excess energy" using magnetic fields, one good example is the HES.
Having used simulators (good Professional ones) for many years now I have a great deal of confidence in them if they
are used properly (like every tool). Brassboards and prototypes match the CAE Analysis quite closely in nearly all
cases that I've done.
Appreciate the offer of Help but it's not necessary - when I sold the lab a few years back I was granted "guest access"
as long as whatever I did, including having the model shop build prototypes, was not used for profit and was not shown
to the public without prior "new management" approval.
Therefore, you all will not likely see any "hardware" in any form from me - I do not want to loose this valuable resource
access! I should add, the Lab does not allow any form of personal appliance to be taken into the Lab - cell phone, camera,
pager, laptop, etc. (it's a secure space - the customers demand this for obvious reasons).
You don't have to believe me that CAE Analysis Simulations do work just fine and do give very accurate results - what
you can do however is contact any one of the "Tool" providers and they will walk you through the certifications, etc.
One good one to contact is "ANSYS." They have been in the business for about 40 years (?) and have a large portfolio
of successes they will gladly share with you.
BTW, I have built many devices over time - started as a Tech, then EE, then Phd Sci, then Chief Eng, then Engineering Physicist,
then CTO/CEO, then decided to enjoy a bit more of a broader life - so I'd say I'm pretty well rounded and experienced in a variety
of sectors. There's a very long list of very successful real projects I've done, and participated in, over the years.
You should know that I only share information on the forums since I believe it might be educational and stimulate others
to expand their knowledge, approach to problem solving and alternative ways of figuring things out.
I believe that my posts have shown that! I won't elaborate further on my approach to posting in these forums nor my past.
SL
tinman
Quote from: lumen on August 30, 2023, 04:30:26 PM
@Brad
(Both methods will leave current flowing in a continous loop producing a huge magnetic field as long as it's kept cold.)
Why bother, as we already have room temperature permanent magnets that can do that.
Super conductivity is over rated as far as i'm concerned.
tinman
Quoteauthor=SolarLab link=topic=19405.msg581795#msg581795 date=1693438748
Quotewhen I sold the lab a few years back I was granted "guest access"
Well reading that, sounds like you are a sleeper
What this tells me is, you could take some ones design from here, have this lab build it to machined specs, so as it works to maximum efficiency, and then never disclose the results here--> (without prior "new management" approval)
Sounds like a shit show to me.
Quotestarted as a Tech, then EE, then Phd Sci, then Chief Eng, then Engineering Physicist,
then CTO/CEO
So fully indoctrinated in the standard models then.
So with all this knowledge, expertise, and time, what have you come up with that exceeds anything we have today ?
I'm guessing nothing, because you are doing the same thing others have done.
SolarLab
Quote from: tinman on August 31, 2023, 04:29:21 AM
Tinman,
Yea - anybody could take anything found here and perfect it - it's a two way street isn't it!
I'm sure many have already taken the "LinGen design" and are "secretly running with it" - I hope so...
Highly likely - since the "LinGen" is the only "Excess Energy Generator Design" that's appeared anywhere that includes
any viable technical detail, conceptual proof,  and is very easy to fabricate!
Could even be Foreign Actors as well  - yea; it does sound like a "shit show" when you think about it!
SL
