Igors switcher (EMF recycler2)
Started by drspark, January 27, 2007, 09:25:42 AM
hartiberlin
Dr. Spark,
as long as you don?t use any transformer and don?t use mechanical switching
with the right contact materials, I guess we will never see any additional energy
coming into this circuit.
It is just a capacitive current transformer type circuit and we need
external energy input via electron clustering at the mechanical switching contact points
or something simular to generate additional energy from the outside of the circuit
to get additional energy input.
I am looking forward to your new tests with the transformer.
Regards, Stefan.
drspark
Hi Stephan,
Just to complete the record I performed the 1 to 100 ohm measurements you sugjested.
freq 307hz
The parts arrived today, transformer is not an audio freq transformer. is standard mains 50/60hz unit.
That yellow torroid any idea how many feet of #24 i should wrap on it?
hartiberlin
Okay, this is also not overunity.
Now if we fold and integrate again the waveform,
we get about 25milliVolts atthe R1= 1Ohm shunt.
This means 25 milliAmps flow into the circuit, which means
an input of 10 Volts x 0.025A= 0.25 Watts.
The R2=100 Ohm resistor gets a power of about
(3.6Volts) ^2 / 100 Ohm = 0.13 Watts, so the output at this resistor is
still lower than the input of 0.25 Watts.
This way, it just will always work only in underunity mode.
Regards, Stefan.
P.S. If you wind a transformer,
try to go first with so many windings, so that you have around
10 Ohms DC resistance of the coils.
kcarrigan
Hi guys,
New caps on order. Thought you'd want a diagram of the 50:50 duty cycle timer circuit I use. Instead of using transistors and components, use this circuit.  The output of course will need something like a MOSFET or biploar transistor to keep the 'Ra' resistor isolated from any output loading affects.
v/r
Ken
gezgin
I have seen miracles happen to men and women in all walks of life all over the world. Miracles will happen to you, too?when you begin using the magic power of your subconscious mind -Joseph Murphy
