Igors switcher (EMF recycler2)
Started by drspark, January 27, 2007, 09:25:42 AM
wizkycho
To all !
This is the frist time I hear bout AKOIL.
Any schematics  ? is it the same as mine.
I know that schematic is so simple, and one can't believe I have no time to try it...
Well I'm preparing for gigantic jump to future with more certanty or rough downfall to the present chaotic oil mud.
so i must allso have time to concentrate...one of these days certanly...
Havent tought of any "obstacles" that this wouldn't work and give FE, a lot of it.
anyway a very nice progress...
Igor
hartiberlin
Quote from: drspark on April 05, 2007, 08:50:56 PM
Hi People
The transformer;
33.6ohms
2.4ohms
hair fine wire could never pass 40W
Power transfer in a transformer does not depend so much on wire diameter size..
resister is brown black (real dark blue) LOL sorry ill remeasure later...
So the output resistor is not 10 Ohm or melted up and you can?t see the
rings anymore ??
I guess the value of this resistor is much higher,
otherwise your secondary with 33.6 Ohms would have had even more Watts
on there ! And then the transformer would have burned up with
its small diameter wire size..
Regards, Stefan.
drspark
Igor, Members,
I am sorry if it seemed like I was negitive regarding your latest circuit, I most certanly am not.
I have collected all the parts required, Except one, the transformer.
For your circuit to work we have to use relay and low frequency transformer 1 to 1 turns ratio, thats the brick wall for me. I/We need a resonate transformer for 20-30hz max operating range of relay. I know its not impossable, but thats the limit of my knowledge.
I have a spool of #24 and that torroid,  the torroid currently has 2wires 3ft long, one centertapped, anyone know what that frequency is?
For the recycler I need a transformer for 10Khz that can take about 5amps.
(or how many double #24 turns on a AM radio ferrite stick. I have one of those also)
Pese, can you help us design 30hz and 10kz centertapped 1 to 1 transformers capable of amps, I really want to get to the bottom of this as do others im sure.
I see a transformer as two gears with many teeth and a clutch or *hydralic torque converter*, go to slow and the clutch slips, go to fast and the clutch slips, when just right the gear ratios transfer power. My analogy is broken when we introduce resonance.
With the caps raising the current, a little bit of resonate voltage rise will make up for the voltage losses at componates and loads, keep fingers crossed I am.
I do not understand the need to bring more electrons into the circuit, ALL the electrons in the circuit are *in the circuit* allready. We need a way to make them move, a charge seperating dipole (battery) or a disterbance. If we kept *adding* electrons to the circuit it would ionize.
Whats needed is ElectroMotiveForce to give motion to the current Druid gas electrons in the metals of the circuit NOT more electrons (mass).
Why speed of EMF (c) not speed of magnet passing coil in a operating generator?
There are many things about electric not understood - that hasent stopped us from harnessing it.
drspark
drspark
Stephan,
With the audio transformer bridged with a real 10ohm not 10meg ohm resister the output looks like the shorted t1 scope shot. Im sorry as I climbed the stairs I was wondering why the resister wasent hot. I kind of expected the same heat. Neither way would light a 6vbulb.
I think because the output flatlines the core is getting saturated?...
The waves look basicly the same no matter which side of the transformer I plug in, when the other is shorted.
The audio trasformer is labeled TSP-1036
spark
drspark
Hi People,
I have greater voltage and current now using 2-1 transformer.
The core makes hi-frequency sound when all is just right...
I will be making up scope shots after i play with other size wire(s)...
The bulb is the brightest ever and a real 10ohm smokes quickly!
drspark
