Thanks to ALL for your help!!
Igors switcher (EMF recycler2)
Started by drspark, January 27, 2007, 09:25:42 AM
drspark
Hi Gezgin,
Great!
Can you describe your transformer?
I have a couple of torroid cores from pc power supplys,
Is that where you got yours?
My relay started malfunctioning, after about a total of an hour.
So try to limit your run time(s)....
sugjestion; get the highest voltage value cap you have and use a bridge diodes after your transformer to convert back to dc and then measure voltage at that cap after 1sec then discharge every cap and run 2sec then 3, 4...
The resister in series with initial charge source must be there. In the sim, if its not the sim_zener breaks from the startup charging current and the voltages go straight up, causeing the transient analysis to fail and in real world if this whole concept works a cap!
In a MOSFET version of this, there must be delay (sawwave drive) in the switching state or they will short out and circuit will malfunction, simulatedly speaking.
How can I tell if my driver really turns the MOSFETS COMPLEATLY ON?
EVERYONE HAVE EYE PROTECTION! maybe face and throat too.
Spark
drspark
Hi People,
For those out there experimenting with the circuitmaker or other spice program; To help with the *Timestep to small error* I copied this from the manual;
Spark
hartiberlin
Quote from: drspark on February 23, 2007, 01:28:18 AM
Hi People,
Berkleys SPICE Simulates overunity solid state and SELF-RUN
by replacing the battery with large cap, removing the blocking diode, and telling the simulator some Initial Conditions, one to set the start cap to 12v and the others help the sim start the multivibrator.
Run the sim and the start cap voltage drops as the circuit charges up and then recovers as the output stablizes. another zener was needed to protect the startup/run cap....
another most interesting result.
anyone out there build this yet? please share your findings.
Best regards,
Spark
Hi Dr.Spark,
what is the switching frequency ?
This looks very simple to build !
I will do this after I am am finished with the Mike motor.
Regards, Stefan.
drspark
Hi Stephan,
Looks to be about 150hz,
I renumbered the componates.
Also starting to gather parts for construction.
Odd caps are ones I have...
Time to settle this, on the bench!
Spark.
gezgin
Hi Spark,Stephan
toroid from local store , it maybe from www.chinadmegc.com(iron powder toroid core) .
diameter: 36mm.coil 0.5 mm wire .inductance is 10-15 mH.
power supply 12-16 V adjustable.
I calculated 555 osc.frequency 32-33 Hz (RA=10k,RB=4.7k,C=2.2uF+100nf).
digital multimeter shows stupid results, idont think  problems about capasitors any more.because connected to caps. a neon bulb and no light on.(only small light at one caps.) I'm curious about caps. wave forms & need scope! ???
my opinion is that creating solid-state overunity is hard .. still we need rotating magnetic fields, magnets ..
I have seen miracles happen to men and women in all walks of life all over the world. Miracles will happen to you, too?when you begin using the magic power of your subconscious mind -Joseph Murphy
