Igors switcher (EMF recycler2)
Started by drspark, January 27, 2007, 09:25:42 AM
drspark
Hi People,
The next morning its 4.7v  so i think is memory effect of battery(s).
Last night I remove transformer, put 22uf cap where battery was, start 3:00am at 7.82v
2:15pm same day 3.99v
Now all thats happening is the c1-c2 caps are changing state from series to parallel at 10hz accross the 22uf cap and the d1 diode that are in series....
The sim shows 22uf cap voltage drop <100mv in 30seconds.
reallity much much different hours have passed and it still has half voltage!?
Im going to get a wall wart to run the 555circuit and set this (relay far) away and let it run....
on to the quiet FET VERSION...
Spark
dorro1971
cheers Terry,
waybackmachine!!!! should have thought of that..DOH!
dorro
drspark
Hi dorro1971 Terry,
There is a egroup that has the servicepack1 (major upgrade) for CM2000 and other infos
http://tech.groups.yahoo.com/group/muug/?yguid=204074595
muug : CircuitMaker / TraxMaker User group
I hope this helps
for googling try;
search token / size of file, if found.
cm2000servicepack1.exe 2mb+-
cm2000.zip 10mb+-
cmstudnt.exe 3mb+-
drSpark
drspark
Hi People,
I have the solid state version of the recycler running
heres a quick look (needs bigger caps) and i forgot the diode.
R1=100ohms R2=6vbulb run circuit bulb glows dim yellow, put bulb in series with 100ohm and power supply and bulb does not glow at all...
drSpark
wizkycho
Hi DrSpark !
Can you make some scope shots on Q4s Gate-Source and Q4 Drain-Source ?
I don't think it swtches properly... but none the less, again very close and very efficient.
Igor
