TopRuslan
Started by r2fpl, March 21, 2023, 11:47:39 AM
forest
Did you get am modulated grenade output ? Low 30Hz on top on high frequency ? How it can be done with Tesla coil ?
NickZ
  apecore:
  Not sure what you are asking about.  Forest, same.
   NickZ
NickZ
  apecore: I do have a sine wave at both inductor and grenade outputs.Push pull  signal,  is a square wave to the yoke.  Kacher circuit output is a sine wave, also.That is what I have.
NickZ
Dog-One
Quote from: apecore on March 31, 2023, 11:48:30 AM
Did someone tried Ruslan' s approach?
For the record, here is the english translation.  Terms not recognized.
Quote from: RuslanT on March 11, 2016, 03:34:00 AM
Hello. Maybe here we will find a common language. I will say right away that I do not sit on the forums much. No time! However, now for the 5th time I am assembling an Akulin installation to increase the power. Have ideas.... And in fact, people are looking for a little bit of everything wrong.
All these systems work on the basis of standing and traveling waves. You must first catch the movement of particles in the coil. That is, as Kapanadze does with the help of a tester or ammeter. Only at RF frequencies, no ammeter will help and you will need to catch with an oscilloscope.
First rule: Wind the coil 40 meters. 2. Find out its resonant frequency (1/4 wave) Inductor 1/4 = 10 meters of the same wire (for example, 2.5 mm) Connect the generator to a 10 meter coil, drive the rectangles at a frequency of 1 MHz and crawl higher, until a sinusoid appears at 40 meters. Peak amplitude. It is advisable to take a normal generator, laboratory! With adjustable output from 0 to 20 volts. Achieve the maximum amplitude and move tenths of the kilohertz until the sinus begins to dance. It's your wave resonance !!! We fix the frequency and voltage. It is for this that all you will have to make generators.
Further... Tesla reel under this frequency that got the effect. Then we do everything like I did or Shark. In this case, everyone wants to repeat this device. Forward! We fix everything beautifully and rigidly, not forgetting that the resonance and effect can escape in cases of fastenings on the snot. We need to get the effect itself and the work, and not a ready-made device. As soon as you begin to understand what to do next, you will be able to move yourself.
So.... Tesla, as we know, also wets the sinusoid. Let's say your frequency is 1.821MHz. Herring frequency, but alas. You'll have to tune Tesla to her. The shark applied a firic between Tesla and the toroid (Antenna) over the inductor. It's just an exact adjustment. It is needed before launching. Then the system holds and it does not matter where what has slid within large limits. But! Again... What's where?
On the Inductor, we feed a rectangle signal with a frequency of 1/50. Consider : 1820 : 50 = 36.4 kHz pumping rectangle through the interchange (Pot) with 23-29 turns of wire of 2.5 square. Again, you need to make the voltage on this harmonic not 10-20 volts, but higher by an order of magnitude. Up to about 50-60 volts and get the same dancing effect at the output.
Further! Do not forget that Tesla does not need strong power. No need to let sparks in and wet so that it pierces. It's nothing to !!! It is better to make a controlled Tesla.
Continue : At the output there will be a voltage of 195-200 volts. This tension will not be higher. Why? We'll come back to that later.
You need to wind the transformer - reactor (Coil) to get the desired voltage. This requires experimentation. Remember that we are pushing the current in the reactor with a transverse wave. Created by Tesla. In the coil, another wave is formed under the influence of pumping rectangles. Particles of which are constantly rotating to the left and right. Giving them the movement of a pulsating Tesla, we accelerate them in the conductor itself. It's a gemmoroic understanding, but a fact. Tesla must be triggered in one half-period or with one arm of the transistor. It is desirable to control Tesla to carry out a pack - a pulse generator. When everything is clearly configured, you will see how the effect manifests itself when you change the width of the pack. Tesla's consumption is minuscule, and pumping does not strain at all. Output current up to 7 amperes and voltage 200-209 volts. Light bulbs and PSU pulse work well.
Now on the takeaway :
1. The coil is connected via a diode bridge. No parallel !!! capacitors
2. You need but from Tesla only one half wave. Otherwise, Tesla will take what it gave back !!! Therefore, the diode from the ground is placed on the reel itself (40m) The shark did it at the reception. He removed one part of the sinuses at the reception itself. Because Tesla. No one knows this and to this day, nichrome doesn't work. It's clear!
You need to swing the swing in the energy recovery coil. That's where we push the current. By the way, the excess from Tesla and the frequency setting Shark used a simple light bulb. Since the inductor is galvanically untethered from the entire circuit, the bulb served as a resistive load of extinguishing excess from tesla and aiming. You don't have to bet, but don't rock Tesla too much. Do not! Remember that the current obeys the voltage. I see this from the experiments that I conducted 2 years ago.
Further: The diode on the receiving reel destroys one half-period and thus we swing the oscillations without slowing them down with a negative Tesla period. Many people do not know this either and continue to sculpt. That's why Roman (Shark) talks about what eats grounding... That's right! Because it kills the pulse of the half period on the reception, which is grounded. This is visible in all his installations! I wondered for a long time why he applied this solution and realized that it is easier to pick up explosive diodes. Since interference at such frequencies in Tesla will lead to its incorrect operation. In other words, cutting off the half-period will not work. Kapa solved this issue by a discharger and rectifiers at bass frequencies. Everything is simpler there, but there are more wires....  So on the German installation diodic small, Tesla is far away, the grounding cable is long. By the way, equal to the length of Tesla !!! Don't forget about grounding.... On this installation it is the main thing and without a good support (grounding) will NOT work. Do not forget that high voltage is used in the systems. As we know, it moves even in the air. That is why grounding is necessary. Plus wave resonance and safety.... Somehow.....
Dog-One
Quote from: NickZ on March 31, 2023, 08:20:17 PM
I think what apecore is getting at is that what comes out of the
yoke should also be a square wave, which makes a lot more sense
because the rise/fall time is what is critical not the frequency.
Certainly would explain why a ferrite yoke works well and an iron
core mostly sucks--get a sine wave instead.  Recall, an ideal
transformer will pass a square wave through it just fine.  The only
thing that will change is the zero reference.
