TopRuslan
Started by r2fpl, March 21, 2023, 11:47:39 AM
NickZ
Quote from: apecore on April 02, 2023, 01:33:16 PM
Here he is showing his kacher frequency w/o antenna  so no load attached to secundairy and it resonates at 3.16Mhz.
Its quit obvisious that Ruslan also used fishwire between his secondary.
Also a nice explanation about tuning the 2SC5200
https://youtu.be/kHdHhXFyRac
the
   Yes, that is  also my Kacher frequency, if I disconnect the ferrite rod and it's opposite wound coils, along with the antenna coil.Otherwise my running Kacher frequency is tuned to  around 1MHz, or so.  I do have the same Kacher circuit replication as he is showing there. Same grenade, as well.
apecore
Quote from: NickZ on April 02, 2023, 02:22:11 PM
the
Ok
But looking at his coil length ( unfortunately all is taped) .. it seems a long coil for 37.5meter  ( 0.5mm wire).
Seems almost 20cm total
NickZ
Quote from: apecore on April 02, 2023, 01:05:40 PM
In vid below he talks about 1/4 wave and resonance at 2Mhz at wirelengrg 37.5meter.
https://youtu.be/CKyV-yA6KMs
  Ruslan talks about it, but does not show the grenade coil free running best at any frequency. Nor the 2KHz frequency. Nor, the supposed 2MHz Kacher frequency, in that early video.
   NickZ
NickZ
Quote from: apecore on April 02, 2023, 01:48:38 PM
In this short vid Ruslan explains the inductor setup and how it creates a puls in our grenade.
https://youtu.be/X8XmF4_Sb9k
  On Ruslan's diagram he leaves out the yoke's 3 turn coil circuit entirely. There is 50 amps of current sloshing around in there. That is what the Kacher  HF HV pulse hits on.
   NickZ
apecore
Quote from: NickZ on April 02, 2023, 03:32:49 PM
   NickZ
But the coil he uses is the inductorcoil... only with parallel cap to tune the pulsduration 250ns.. which he drafted as a transmission line.
The 3T drawing is not used.
This could be his unipolair puls system.
