TopRuslan
Started by r2fpl, March 21, 2023, 11:47:39 AM
apecore
Quote from: Dog-One on March 26, 2023, 08:46:06 AM
So if your Tesla coil is pushing 2MHz through the antenna into the grenade, that same
signal can come out through the inductor, through the push-pull
transformer and be shunted by the push-pull drivers.  Not what
we want.
Good work Dog-one,
Reading it twice and thinking about it is exciting. I like it the way you tell it...  :D
Sounds like a plan.
So the bad news aint mayde not as bad as we think, giving oppertunity.
I understand this issue, but we need to consider adding hardware could eliminate the 'effect' or gain
We dont know?
But we need protection probably to avoid damages on hardware.w/o shooting us in the foot.
Just out of the box....... Verpies lossles clamp idea would be an option?..... this lossles clamp has potential.. with extra functionality to measure something?
Dog-One
Quote from: apecore on March 26, 2023, 11:01:28 AM
This is my configuration.
I added pp foil between layer 1 and 2 for mor capacitance in order to get the 2.0Mhz region.
"pp foil" is that metallic with a split?  No split?  Non-metallic?
Made a mistake in the drawing, grenade is now verified.. has 33.5uH .. and resonates approx at 2.0Mhz
You always have to play with the last layer to get it +/- 5khz
Layer 5 and 6 I messed up
Small vid for frequency verification after rewinding;
https://youtu.be/Tb7aV_GVMDI
Very good.  I can work with that picture and see what kind of fudging
I have to do with an AC analysis sweep to see if I can match your
actual resonance point.
Your inductor turns would be a separate layer over layer's 1 & 2 correct?
Antenna same thing over all layers?
Quote from: apecore on March 26, 2023, 12:51:40 PM
We dont know?
I recall some of the old videos where Ruslan was inserting capacitors
into the schematic--maybe to fix this problem?  I didn't think about
passive filter elements at the time, but it makes sense now when I
think about it.
I made a nice lossless clamp board with a SG3525 chip.  When I
connect it to a good nanocrystalline core, I can get power-in /
power-out of almost 100% conversion.  The best part is I get
that ratio regardless of what kind of load I attach.  If there is
any impedance mismatch, the reflected energy just goes right
back on the DC bus and gets recycled.  No heat loss in snubbers.
apecore
Inductor and antena
Yes antenne at inductor position
apecore
Quote from: Dog-One on March 26, 2023, 03:04:00 PM
Polypropyleen sheet where you can put in paper for clean protection
Yes
Only inductor position
think about it.
I do have such a core, two pieces together.
I guess we first want to what happens with HF in respect to losses and risk.
Bit thinking about how to ake it smart is good, so we can optimize hardware.
Dog-One
Yes, if we know what the components should do, we can possibly
make things better.  When we don't know, we really only have the
fallback position of doing what Ruslan did.
