Buoyancy device by phase change of water to ice
Started by Willy, April 13, 2023, 05:23:35 PM
Willy
Agree
It needs organized and drawings.  I'll get to it when I can.
thanks
Willy
The process begins with the drawing below.
The freeze thaw pump is a heat exchanger for the adsorption of heat from water /
freezing of  water. It should have been labeled as a freeze pump in the drawing.
Its energy source could be a heat radiator and pump located above the water's surface,
in cold arctic air. A cooling fluid is circulated between the radiator and the adsorber.
Cyclically the Ice is discarded and new water taken in and frozen.
The water expands upon freezing, presses a hydraulic fluid through a piston cylinder
and moves a piston.  It is a water phase change driven, hydraulic press.
Note that, Only for simplifying of the math, did I assign a 1 square centimeter surface area to
the piston.  As a result, this give a very long piston stroke (caused by the hydraulic pressure
/ fluid) 80,000 centimeters length.  It will be more practical to have a larger piston diameter
and a shorter piston stroke.  This would however, necessitate the changing of all of the various
mathematical ratios given in the exemplary model of its operation.
The hydraulic press / piston's motion is used to draw / pull a vacuum in another piston and
cylinder. I have referred to that   other  piston and cylinder as a syringe (like unto a syringe used for hypodermic injections but obviously much larger).  That syringe pulls nothing into itself
as it expands. An empty space / vacuum in relationship to the surrounding water pressure
is created instead.  The syringe is
                                              LATCHED
                                                    in that position until it has arrived at the surface
of the water.  I hope this helps for now.
                 EDIT
               And math checked
1280   kilograms of buoyancy  x 1101 meters of depth = 1,409,840 joules.
        not 14,092,800 joules.
Willy
joules by ice rise from 1101 meters of depth  is 0.8 kg x 1101 meters = 88.08 joules
80,000 cubic centimeters under vacuum against 14.7 psia at sea level = 8,108 joules
                                                       joules from water to ice expansion =  1,409,840 joules
        Total = 1,418,036 joules
          1,418,036 joules total out  to  4,184,000 joules in
                             2.9674 to 1  less than 33% efficient
                            Probably more like 25% efficient after cooling fluid pumping cost.
                 but useful
Positives / informative
The difference in energy content of a vacuum "filled" float as the result of
temperature changes
from
the energy content of a gas filled float as the result of temperature changes.
Buoyancy neutral vertical drive chain (up and then down after rounding a gear, then up again
after rounding a second gear.
