POWER PLANT WITHOUT MECHANICAL BEARINGS UCRÓS ELECTRIC CYCLE OF 5 KW
Started by kampen, May 10, 2023, 01:36:50 PM
kampen
POWER PLANT WITHOUT MECHANICAL BEARINGS UCRÓS ELECTRIC CYCLE OF 5 KW.
[size=0px]Carlos UKROS Colombia POWER PLANT WITHOUT MECHANICAL BEARINGS UCRÓS ELECTRIC CYCLE OF 5 KW[/size]
kampen
The LOAD is connected to the INVERTER.
Pure Sine Wave Inverter 12 V, 24 V, .... 110 V 5'000 W
https://www.aliexpress.com/store/product/LED-Display-5000W-pure-sine-wave-inverter-12v-24v-48v-to100v-110v-120v-220v-230v-240v/413804_32478890376.html
Special Electronic:
The right bright element is the timer which gives the signals to the disconnect relay and switches from one battery to the other (all 5 minutes).
That means each battery is 5 minutes long and connected to the inverter while the other is connected to the charger.
And after 5 minutes the battery connections are exchanged.
The 4 rectangular dark boxes are Battery Disconnect Relay, type WM 686 RL/280-12 12 V/200 A
https://www.google.ch/search?newwindow=1&safe=strict&tbm=isch&q=WM686+RL/280-12+12+V/200+A&spell=1&sa=X&ved=0ahUKEwjOjZLviNHYAhVErRQKHfT2BO8QBQg7KAA&biw=914&bih=454&dpr=1.75
https://roundupreviews.de/de/pkw-camping
Buying for €7,79
The nominal switchable current is 200 A, peak current is 240 A.
Electronic Power Relay (recommended by Peter Furrer for frequently switching applications)
https://www.mouser.de/ds/2/645/D_EPR10_ENG-1128473.pdf
The electronic power relay EPR10 is a solid-state relay for high continuous currents. It is suitable for use in utility vehicles and special vehicles where reliability and functional safety are at a premium. At DC 24 V, the EPR10 allows a continuous load of up to 200 A.
80 % less space requirement than similar conventional solid state relays: - no heat sink required - low internal resistance through parallel connection of power semi-conductors - technically mature heat management - cooling through connecting cables l
Low investment costs: - blade fuses in sub-paths and heat sinks are superfluous because the EPR protects against overcurrent and short circuit l
Minimized maintenance costs: - enhanced availability due to a much longer life span compared to mechanical relays - very high resistance against dust, humidity, vibration, and shock due to the sealed electronic circuitry Price: 333,44 €
panyuming
Wish to know:
two battery currents;
Load current.
Thank you!
