Wanted - Electro Mechanical Relays Search
Started by russwr, August 01, 2023, 07:38:00 PM
stivep
TommeyReed
stivep,
Looks like a outlet box you can buy from Lowes or Home Depot, simple relay box I can make for pennies and sell it to you for $450.00
LOL
Tom
stivep
Quote from: TommeyReed on August 02, 2023, 03:51:29 PM
stivep,
LOL
Tom
It is a vacuum relay. Never used, certified, military grade.
The original price for it per piece , was around $6800  "on that money" in 1990-
I'll  keep it  to build more powerful device I have.
Wesley
Sergh
I think such monsters will be difficult to handle.
Normal small vacuum relays, more suitable for those described in the first message:
https://www.ebay.com/itm/145191176733
Relay data:
https://eandc-ru.translate.goog/catalog/detail.php?ID=4707&_x_tr_sl=ru&_x_tr_tl=en&_x_tr_hl=en
or similar to these:
https://www.ebay.com/itm/364368464079
It is not clear what function the relay should perform. If it is necessary to create many pulses  60 Hz with a mechanical switch, then you can look at such ancient devices:
https://www.ebay.com/sch/i.html?_nkw=DC-AC+Chopper
But this devices mostly are for very low switching power.
ramset
Russ mentioned small engine
3-4000 rpm ( cycle speed of relay contacts
High voltage (car ignition ...maybe higher voltage "plasma" as per some water fuel claims ?
Nothing there that should not be impossible to find in vacuum relay ( double solenoid? Perhaps exotic metal on contacts?
Interesting if this component is make or break on it working?
Thanks Grandma
