Self Looped Cap Dump Bedini Motor
Started by joellagace, August 21, 2023, 07:00:40 PM
Dave Wing
This is the symmetrical AC waveform of an all north Bedini SSG.
Dave Wing
Here is an example of a asymmetric produced waveform in between two north poles on a rotor. It is more negative than positive in amplitude. This waveform can become more positive and less negative when the rotor rotation is reversed. Everyone has heard John Bedini, Jim Murray, Paul Babcock, Thomas Bearden, erfinder etc. talk about asymmetrical waveforms and what can be done with them.
Specifically how rotation in one direction can cause CEMF to flow with the applied voltage, increasing recovery and performance of a DC pulse motor and rotation the other way causes CEMF to oppose the applied voltage.
Dave Wing
tinman
Quote from: Dave Wing on August 30, 2023, 09:37:41 AM
This screen shot was taken from https://youtu.be/OSJF3GlYGVc?si=50EryhVsEiPSidTb
The image analogy is for a small DC non-pulse motor, where the inductive kickback is discharged into the motor windings.
Peter Lindemann describes BEMF, the video is very good and is the first part of a three part series on Electric Motor Secrets.
Found here https://emediapress.com/shop/electric-motor-secrets/
I recommend purchasing these video's for your library.
The videos, books, and the pulse motors show nothing at all out of the ordinary.
Their books of secrets have no secrets.
They just peddle garbage and lies in order to make a buck.
tinman
Quote from: Dave Wing on August 30, 2023, 09:49:46 AM
You get the same waveform passing an all south Bedini flywheel past the coil, only inverted.
There is nothing at all special about any of bedini's motors or contraptions, other than they kill perfectly good batteries.
There is nothing special about an all north out flywheel.
In fact, the best configuration is to have alternating fields around the rotor.
Dave Wing
Quote from: tinman on August 31, 2023, 09:30:34 AM
I don't think it is garbage, in my opinion they are trying to get us to think about this... the lesson's I gathered is to use the CEMF to work with you and not against you. CEMF can be recovered along with the inductive coil collapse. That is the lesson they teach.
Dave Wing
