Pulse Motors- Your building them wrong.
Started by tinman, August 30, 2023, 12:55:41 PM
MagnaProp
Quote from: bistander on November 05, 2023, 11:48:37 AM...Use Ohm's Law. V = I × R. Or I = V / R. So your 12 volt supply divided by the 6 ohm resistance of the coil takes 2 amperes to satisfy the equation...
Hi bi. Thanks for all the info in that post. It has helped me understand it a bit better.
Quote from: Thaelin on November 05, 2023, 08:14:11 PM
All:
    I am off line for a bit...
Mags:
    The coil I have is an old wire spool from RS with 2 strands of #20 looped to one and will draw about 3 amps if I let it. Will in fact tho repel the 2 N43 .5 X .5 inch neo's...
No worries Thaelin. Life often gets in the way and it sounds like you are doing what needs to be done which is good. I for one will still be here when you get back up and running since I have a bit to go in learning how to make a pulse motor circuit and such. It'll be good to have you back when you're ready.
Thanks for the info on your spool and setup. I made a tweak to my electro magnet that got it up to 190mT using the same 15.5 volts and 3 amps as before but even that only matches one of my neos now. I was hoping to get up to about 400mT which is about 5 neos stuck together. So I'm still thinking of making a new coil.
rakarskiy
Quote from: MagnaProp on November 05, 2023, 07:34:43 AM
I'm trying to understand this better. I understand that amp turns is the amps times turns.
I don't understand how we got the 2 amp info in (2 amps at 12 volts= 24 watts.) from knowing only (300 turns, and it has a resistance of say 6 ohms).
So we started with 300 turns and 6 ohms resistance. How did we get the 2 amp value from that?
To calculate the voltage drop in a circuit, we use the following formula: I=Ui/R, where I is the current in the circuit (measured in amperes, A), Ui is the voltage drop (measured in volts, V), R is the resistance, the unit of which is the ohm.
In this case, the formula for the effective voltage in the circuit is U=IR=E-Ir.
Power is defined by: W=UI, at the same time the current corresponds to the expression: I=U/R.
For the value of current in the circuit (source + load) the following condition must be fulfilled: Ui/R=I=U/R
it is kind of an axiom.
An example of circuit calculation is at the end of my article.
https://rakatskiy-blogspot-com.translate.goog/2017/08/generator-of-free-energy-vega-ukraine.html?_x_tr_sl=ru&_x_tr_tl=en&_x_tr_hl=ru&_x_tr_pto=wapp
Excel spreadsheet for calculating circuit elements:
https://docs.google.com/spreadsheets/d/1aRyIXNVCGkBHZj6Nzhjejwpj0LJ_kfmA/edit?usp=sharing&ouid=103757942593314724986&rtpof=true&sd=true
MagnaProp
Thank you. Math and I don't get along too good so I appreciate the help on that.
