Efficient Ambient Energy Utilization.
Started by joellagace, September 13, 2023, 04:12:45 PM
joellagace
In this youtube video demonstration, I present an unusual observation that became evident after shutting down my trigger generator. Even with the trigger turned off, residual energy persisted in the system, most likely due to ambient induction. I utilized this lingering energy to activate a high-voltage pulse module, which then pulsed back into the coil, effectively taking over the role of the original trigger.
The result? Output voltages soared into the tens of volts range, accompanied by substantial production of radiant energy. This was verified by a rudimentary radio setup that I had at hand.
In the video, you'll find the schematic outlining the setup. This configuration could potentially serve more sophisticated applications—perhaps energizing your capacitor discharge circuits or similar endeavors. The further potential of this arrangement remains an open field, inviting your exploration and ingenuity.
https://youtu.be/ZbnNPfvI_DY
adrouk
If you keep experimenting soon enough you'll find out that you don't even need a power source to extract what you're looking for
Cloxxki
Switched off, but also fully disconnected, avoiding air gap and other forms of connection?
Have you tried immediately after disconnecting, to remove the source by a significant distance, 10 or 15 meters, to compare readings? Just to make sure what you call "ambient" is really ambient.
adrouk
Yeah sure, everyone who gets fe/ou is a hoax, or just stealing from power grid  ;D
joellagace
Well let's put it this way  ;D I found free energy a long time ago. I also found this site gets trolled, Much of the activity here is trolling actually for some reason.
So it's my way to have a bit of fun with it and come on here from time to time to "troll" the trolls  8) As you can see it works!
And who knows, Once in a while someone legit comes by, If they can use the information. All the power to them.  ;)
It's my way of having a little fun with the "that will never work" folks. While still providing some valuable info to those who dare to experiment.
Take care!
