Over Unity With Capacitors
Started by joellagace, September 18, 2023, 10:53:43 AM
joellagace
Today I come bearing updates from my generator, where I've been conducting further tests with my coil and frequency generator setup. Many of you will recall that I have been using various configurations to observe their efficacy, specifically looking into high-voltage modules and the role of back EMF.
After some adjustments, I switched out my original inverter for a high-voltage module and paired it with a 2.2 uF capacitor. The change has been noteworthy, so I felt compelled to keep everyone in the loop.
I started my experiment with a very low voltage in my super capacitors—1.2 volts to be exact. Over the course of this testing session, the voltage rose to 1.4 volts, corroborating the efficiency of the capacitors in this system. My meter readings offer empirical evidence of a consistent charging pattern, clearing the air of any speculations around lead acid battery anomalies.
The game-changer was found when I dialed in a high frequency of 22.7 kHz at a 12% duty cycle to start and gradually decrease as charge builds up all the way down to 1%. At that particular setting, the system resonated optimally and the energy flow started making sense. Those interested in replicating this can find similar high-voltage modules on eBay for just a few bucks; they serve well as both voltage multipliers and isolators.
I plan to release a detailed documentation of this experiment—covering every component from the resistor to the coil dimensions. My aim is to give you all a comprehensive guide for replication.
Remember, we are tapping into energy pathways usually overlooked by conventional methods. The coupling of this high-voltage module with a resonating LC circuit, drawing back EMF into the system, has led to a loop that, theoretically, could surpass the capacitor's rating if left unattended. The system isn't just self-sustaining; it's increasing its own energy storage over time. We are essentially creating a harmonic resonance with the environment, acting as the other side of the dipole.
I look forward to your comments and insights. Let's collectively push the boundaries of what we understand as 'conventional energy systems.' A full release with all relevant details will be coming soon. Until then, happy experimenting!
https://www.youtube.com/watch?v=UPn11DTvgnQ
ramset
Joel
Just making you aware of another researcher experimenting
With capacitors ,
He too has put tremendous efforts into this type of research
And he shares open source ( as you do)
Member Ifarrand
10 ? Avalanched capacitor test units?( post 106 and 108..)
https://www.overunityresearch.com/index.php?topic=4467.msg107024;topicseen#msg107024
Ifarrand
I'm now working on a circuit to discharge 10 capacitors in sequence, whilst charging them in parallel (when not being discharged).
I put together this infographic to describe what I'm trying to achieve:
End quote
Thanks Grandma
joellagace
adrouk
@Joel, would you consider a short explanation and method even without parts list just to make sure stays open source and nobody try to patent your discovery ?
It seems that a lot of hunters are everywhere.
joellagace
Quote from: adrouk on September 18, 2023, 02:42:23 PM
Right here!
https://youtu.be/WzuRruKdFI0
