Tommey Reed's Water Experiment To Create A Fuel?
Started by TommeyReed, September 23, 2023, 03:12:39 PM
onepower
Quote from: seychelles on September 25, 2023, 05:02:05 AM
HI TOM THIS MIGHT INTEREST YOU GREATLY. IT SHOULD BE EASY TO REPLICATE.
https://www.google.com/search?client=firefox-b-d&q=malcolm+bendall+plasmoid+generator#fpstate=ive&vld=cid:0d609875,vid:sVgY9pcYAL8,st:0
Looked at the Bendall PDF and it looks like a GEET setup with an external ionizer.
GEET link, http://www.rexresearch.com/pantone/pantone.htm
The language about plasma/plasmoid reformation is almost identical. The GEET link has a wealth of information directly related to what Tom is working on.
In effect, they take the water spark plug circuit Tom just demonstrated and make a bigger spark plug as a rod within a tube. The larger surface area of the rod/tube expands the plasma reaction surface area.
AC
TommeyReed
Hi All,
This is the patent in 1991 that is the key to run any engine off water.
https://patents.google.com/patent/US5159900A/en
Tom
adrouk
Great work Tommey,
Soon you will find out, that this is a very good solution for static setups or transport on water, as it is quite impractical for a mobile (land vehicle) where you need well above 200 l for 30-40 miles journey unless you can make something to use same amount of water as the original fuel design because of total weight of water you need to carry, not to mention freezing in the winter.
Overall it is a good thing as long as will push out oil industry from transport and other purposes which pollute the environment.
TommeyReed
