Tommey Reed's Direct Water Injected Engine Project.
Started by TommeyReed, October 16, 2023, 07:20:04 AM
TommeyReed
Hi All,
I have been busy.
Victor Fischer has patented a direct water injected steam engine and I found more information on what he was doing.
Basically he used supper heated water in a none pressurize containment and injected into the the engine with a temperature of about 530.deg - 1,165.deg.
This instantly was converted in to super heated steam.
This is the patent:
https://patents.justia.com/patent/4747271
I was only able to find one drawing and yet there should be 10.
I will study these claims in the future project.
Tom
kolbacict
Quote from: TommeyReed on October 16, 2023, 07:20:04 AM
530 degrees Celsius is no longer water. The critical water temperature is 374 degrees.
If it's not Fahrenheit for you. But maybe that's even good... :)
h20power
Hello Tommy,
Again I come back to what I said about breaking the bonds of the water molecules by way of taking away the electrons from the atoms that make up the water molecules. When something is supper heated the high motion of the molecules start ejecting the electrons away from their atoms and there you have the magic behind what that man did. As again any method you can think of that gets the electrons away from their atoms will work at breaking the bonds of the water molecules.
You see heat will do the trick as it makes the atoms move quickly and hit each other, also known as collisions, knocking off the electrons and again once you take away the electrons there is nothing left holding the water molecules together. But do note you have to take away two electrons just as a plant does in Photosynthesis or a Thunderstorm does when gets the atoms to eject their electrons by way of ionization which is what Meyer mimicked.
So, is all of this starting to make sense now in what I am saying? Remember I made use of the scientific method to get at the science behind the patents and that in which I discovered is something totally new to the scientific community. The theory I came up with will one day be in our science books for others to learn from as that is the way things are supposed to go when a new discovery has been made and verified. The verification of this theory I came up with is all over the place but like Meyer would say, "One has to ask the right questions."
gyulasun
Hi Tom,
You can find the full patent with all the drawings here:  https://patents.google.com/patent/US4747271A/en?oq=us4747271
This is the patent:
TommeyReed
Hi All,
Thanks for the information Gyulasum.
This is a new update on the plasma reactor.
https://www.youtube.com/watch?v=YCA9XR0FV-c
Tom
