Over Unity Systems In The Past
Started by russwr, October 31, 2023, 10:48:38 AM
russwr
        Over Unity Systems In The Past  -- Many years ago, there was page article with drawing of spiral vortex dual 110v AC transformers that would provide higher wattage on output. (You know about the tornado effect) The unit was tested on refrigerator with proper meters and power factor. Also the best wind mill generator design was the US Patented "Tornado Turbine", Also the late Mr. Baumgartner demonstrated a hover platform lifting effect with small wattage train motor rewired in series for speed, and vortex spinning vanes. He had used computer program to design it. It was shown lifting him in a room and then later, the front end of city bus. (Swirl the ETHER in certain spiral fashion)
1950 Military motor pool soldiers converted used oil furnace to run on water. Fire pot at 1500 degrees then allows super-heated steam from SS tubing heat exchanger to add to 90lb oil flow to tiny pin point oil nozzle. When steam exits from 90lb high pressure to ambient zero pressure in fire pot the hydrogen and oxygen torch flame keeps heating. Oil valve shut off. If water line shut down, furnace has to be restarted on oil. Much smaller  version in crate was shown to Washington senator in underground parking lot. US patent application was refused. Why can't anything be purchased. (Decrease in temperature required for steam disassociation)
      Alexander US Patent 3913004 1975 The technique of rotation with transformer effect (double wires on rotor) as in the above Patent method to increase energy, allowed inventor to make self running car with 4 air motors at wheels with air tank, battery , alternator, and modified military motor/generator with excessive output torque free energy to run main air compressor. (Input magnetic field revolves armature, 1st wire induces into 2nd wire for field, 2nd wire delivers additional magnetic field increasing torque + speed)
The Stan Meyer Patented ionized Hydrogen gas H+H+O-- generator is way over unity (not electrolysis) and usable since the Patents time has ran out. (Frequency of burst mode input pulses matches the L and the C water capacitor cell with 3000% efficiency - sometimes called voltrolysis - not electrolysis at all)
In 1980's New York there was a self running air compressor with no battery or motor. The main shaft had journal with air cylinder that had higher pressure coming from inherent vortex tube higher pressure than 40lb tank + insulated heat chamber. Unit had spoked, balanced, heavy rim steel flywheel. Tube had 3 machined parts from 3 separate work machine shops, so as final design as put together would not be known. Inventor was mowing lawn outside trailer with long air hose hooked to tank. The interested Company reneged on the $3 million dollars wanted after 1 year.
John W. Keely had shown demonstrations in 1890's Phil. Pa, of lifting effect (no gravity) with resonance frequencies and harmonic ratios using array of tuning forks and multiplication of higher vibrations on heavy metal spheres .His "transmitter wires" of gold, platinum + silver, are now called thermocouples and thermopiles. Witnessed by engineers, newspaper men, and investors at that time. Tesla didn't like Keely since Keely got more investor's money than he did.
S1R9A9M9 (Nathren) of 2008 videos showed Briggs mower engine self running over unity with water in carburetor. Hydrogen gas electrolysis at spark plug with also water vapor pressure generated same time at neg 34 degrees ATDC. Magnetic field coil - called triple coils assy, over plug wire extends firing time for more contact with water. EGR improves performance with Nitrogen addition. Alternator with magnets under flywheel provides constant 10 amps after battery was disconnected. Web site shut down. Special vacuumed sealed dual 1.6MH coils relay per cylinder also used for time spark extension. His CONVERTED carb type 1978 V8 El C amino tooled around town on 18MPG water until locked up in security garage.
You don't know about specialized information because you want data dropped in your lap, rather than doing your own science research yourself and finding out what others have already done. Back issues alternate energies magazines, documents you have to purchase, and published data on Internet YOU have to search for. See DVD VHS movies The Water Engine and 1949 Free For All .
bistander
bistander
Thanks for the paragraphs.
These all sound like scams to me. I have heard of several, and know of some who have explored them, to no avail. To my knowledge, none have been replicated.
It is a stretch to call those "Over Unity Systems", IMO.
bi
rakarskiy
Fraud can be different, and those who hide technologies in the archives and prevent their dissemination. For the first time I heard about such a device from a veteran of the Second World War, they captured a group of Abwehr in Austria and they had an interesting power source for a portable radio station, which in appearance resembled an umformer started by a cable and provided energy to the radio station without a battery. The second story I've already heard about a similar related to John Bedini, in principle acquaintance with a similar device that was taken out of Germany given a U.S. soldier and determined his passion for the subject. The third episode is the story of relatives of another World War II veteran electrical engineer, who on his deathbed disclosed to his relatives that in 1945 he was involved in the work of SMERSHA (military political police of the Communists of the USSR). His task was to transport a single-seat fully electric submarine from an underground dock to a ship for loading. He assured that the power source on board was a self-rotating generator. You can just accept as fantasy stories but even afterwards there were episodes that the system just shuts down.
https://rakatskiy.blogspot.com/2021/02/mystery-nikola-teslas-electric-car.html
bistander
Thanks for the information. Why are none of these replicated? Answer is obvious; none work as claimed.
bi
