testatika scheme...
Started by Aerny, February 07, 2007, 03:53:52 PM
barbosi
Quote from: Grumpy on February 08, 2007, 07:42:49 PM
I have seen posting of working replications - I'll dig them up and post.
please do that.
you're this first I've heard about working replications.
So far personally, I've seen only attepmts to explain the machine.
If you have more, please share with us.
Thanks.
When the Power of Love overcomes the Love of Power, there will be peace.
Implosion
Hi all,
My name is Peter from Holland, I just registrated here.
I have studied this for more then a year now, and i am almost certain, how it works.
In the tubes is no radium or any radioactive materials. Just copper wire, glass ( against sparks ), aluminium and again glass ( against dust ). These tubes are getting charged by ions from the air. This is where the energie is coming from. ( you put a negative charge on the wire, and it attracs positive ions from the air which are getting on the alumium tube ) it only works with high voltage.
Futher, the perforated lamels on the 2 discs, are made from chroom-steel ( rvs 410 ). it can be made magnetic. and it will be magnetic while running, because there is coming through a high voltage. ( only negative or positive ) This is a part of the key for spending around.
I have allready the two discs ( one meter diameter ) glas and vinyl. I am working in a fabric, where we make perforated metal plates. I have allready the chroom-steel plates. My uncle is making the drawings in autocad for the perforating plates, so it can be fabricated on my work.
I dont need the low voltage ( 220 - 270 volts ), so i dont need the big transformers in front of the testatika. I need the high voltage.
I also have studied, the flying saucers from the germans, and its easier to understand that then the testatika.  I did not explained everything on the testatika, but when i am finished, i will give the invention free away. and will go on with more ancient inventions. since I am a child, I have allready inventions in my head, like the implosion technik, and I have seen very strange things in my life. so there is more then only the " normal " people think. There is also a city under the ground beneath the pyramides in egypt. ( if you go there on holiday, you will see near the pyramids, that a gate is guarded by military )
I hope i have finished this device by the end of the year, you must understand, that it is expensive. so every month i buy something. I dont need so much anymore. The discs costed me together 750 euro's. ( one meter big, 10 mm thick ). I want to build a good one. so it cost some time.
I hope one day, that everyone knows the truth about past, free energie devices, and ufo's, and why they are here. I am certain, that in a few years, something bad will happen on this planet. and it has to do with the maya calander.
Ok, this was it first.
Greetings from holland.
Aerny
Ik ben erg benieuwd!
Keep us informed
Steven Dufresne
Is this the replication you were thinking of?
http://rimstar.org/sdenergy/testa/testareplicationjr.htm
I'd noticed that the website that had been hosting it disappeared,
the second time that's happened, so since I had a saved copy I
uploaded it to my site above. Hopefully that means the link will
be good for a much longer time.
-Steve
http://rimstar.org
He who smiles at lofty schemes, stems the tied of broken dreams. - Roger Hodgson
pese
The "title"  say it !!! :
Testatika Clone from or by Jorge Resines.
Shown "as" equivalent ,but "shure" only as designer  modell .
not an working clone,
