Is this the first selfrunning overunity motor w/o batteries ? Mike?s motor
Started by hartiberlin, February 14, 2007, 08:30:03 PM
TheOne
mike motor work without any battery? the motor can run using one capacitor?
hartiberlin
Hmm,
today John Bedini thinks the Mike motor modification is
a fraud.
Look at this, what the Bedini lab guys just posted:
Here is the Myth BUSTED:
http://www.rpmgt.org/TheMikeDuplication.wmv
I must say that I was mistaken. I thought it was not a battery at
first. But in the end after John played with all possibilities I did
suggest to try a 9v battery, while Peter mentioned we need to put a
resistor across it to slow down the affect. After trying a few
resistors we got the desired results as you see in the video.
Rick
TheOne
ah :(, it's that i was thinking... when you see the video the voltage increase a little bit, when he discharge the capacitor, it's not a normal phenomenal :)
at least bedini confirm the hoax!
z_p_e
Well, I don't know if I'm ready to completely throw in the towel on Mike's mod, but if he did indeed cheat by using a battery, would the relay he used be large enough to hide a 9V battery in? I doubt it. If he did use a battery or batteries, they must have been quite small in size.
I have to admit, that after viewing the two scope shots showing with and without the Hall working, I could not understand haw Mike could be getting a positive spike (you have to invert the scope shot remember) when the L2 coil would clearly recoil in the opposite direction, or in other words, a negative spike.
When I did quickly try triggering the switch function performed by the ssr, I noticed only that the already exisiting NEGATIVE spike at that instant became larger. Mike's scope shot clearly shows a positive spike "riding" on top of the negative spike.
So, did he cheat? I for one am not certain yet, but I will try this battery trick to see if I can achieve the same scope shot Mike posted.
Regards,
Darren
ResinRat2
May the fleas of a thousand camels infest Mike's fraudulant armpits!
I have many other choice words to say, but I don't want to seem angry and mean.
There are really quite a few mentally sick people in this world.
Thank you Myth-buster-type dudes! Sorry you had to go through all that trouble.
