Ed Gray Motor bitte auf deutsch!
Started by pulmoll, April 30, 2005, 11:42:18 AM
valveman
I have reviewed the plans for the fuelless motor and have some reservations.
They are using 36 gauge copper enmalled wire.  The voltage is about 1000V for a duration of approx a usec or so.
Imagine expelling all that energy into a tiny piece of wire.  You have the voltage go nearly to 0V while the
current is enormous.  How then can a 36 guage wire withstand the high current?
If you say it's only a duration of a usec and so the wire does not have enough time to get hot then I say think about lightning.
It's duration is only a usec but look at the devistating effects.  Yes lighting has a potential of millions of volts but consider the scale.
I would suspect as soon as all that energyfrom the discharging capacitors finds a path to ground, the wire will vaporize.
Anyone care to comment?
Valveman
fcpeace17
Correct me if im wrong but do they not vaporize because what is running through them are not electrons, it is cold electricity?
