A new way of generating electricity
Started by klaudio, February 18, 2007, 10:59:43 PM
whitehat
This idea deffitly has potential ,  atleast how i see it.
A few miles from shore... on see ocean you add the wheel + the self windup thingy...
The part he now lift with his hand.... attach a rope to it and something that floats on the ocean.. then when a wave comes ... the floating thing pulls the thing up from the bottom... and when the wave go away.. it fall.. and then it wind up......
Verry clever... absolutely has potential.. a open mind can see this works.Perhaps economicly not worth... however it will work.
TheOne
starryskyguy
About forty years ago, one of the major monthly tech magazines (Mechanics Illustrated or similar) had a cover story of energy from the ocean.  This would have used a 300 foot diameter fan immersed in the Gulf Stream off Florida.  These are not difficult to build in drydock and float out to a location, as that is done for drilling platforms that size now.  The four knot current would turn this turbine at slow RPMs so that edge gears drove generators.  A few thousand megawatts could be extracted from the ocean current by a couple of these units.  The current is driven by the turning earth, and the difference in temperatures of ocean water at North and equatorial waters of the Atlantic.  The fans are non-poluting, cheap to operate, almost invisible, and take up no land area (NIMBY not a problem).  This would solve all electric energy generation and future fuel needs in the USA.  And so what if the British Isles and most of Europe would go into a deep freeze because of a change in the current?
http://www.npr.org/templates/story/story.php?storyId=16713781
http://bbcat.org/OceanCurrentPPaper_000.htm
aleks
This device should be made bi-directional: that way it will generate 2 times more energy. Idea is actually good. Of course the structure should be optimized because in its current form it has a lot of friction going on.
