rotoverter for power generation
Started by dan, May 02, 2005, 03:57:50 PM
FatBird
scianto
Just to inform you that running rotoverter on even lower voltages, even if it is
shaft coupled with another motor, can require very little power.
Here, one of experiments I was doing yesterday:
http://www.youtube.com/watch?v=D7AJspQm1e8
Industrial motor 5,5 kW (at 50 Hz) is powered from one phase, runs (1452 rpm)
faster than standard rotation (1430 rpm) and consumes only 0,45 A at 14,5 V
which is 6,5 VA (probably less than 6 W).
The prime mover runs another motor of same type which is not loaded. The
friction of both machines is the only load.
It was running for half an hour and then stopped, probably the voltage went too
low, maybe 14 V only, that was too low.
Imagine how low power it would require if the bearings were ceramic.
Cipriano
Hi, i want somebody help me to replicate the portable rotoverter to use for 3 refrigerators 110 volts or make 3 portable rotoverter for each refrigeratos. I think the portable rotoverter is the best for me    being that i want to use something small, simple and powerfull and cheaper. and clean,the other samples of rotoverter are too much for me and for my needs. i have 3 phase with 9 amp each one. I am in Mexico so here is 60 hz.
I have 6 months translating and studing  documents and i am makin a  new resumen to find what is missing me to determine how to choose the motor, how to choose the rotoverter model to use appropriate for my needs.
I'v read the RE-OU v6-1, document in word how to convert electric motor in rv, The Energy saving aplications principles also the laymens_RV_STEP_BY_STEP3, I have saw the video ROTOVERTER koneheadx and also all the video from Prosperforall,  and many more and i cant determine how to replicate portable rotoverter to use for saving money in energy. I am determined to do that.
I am not an engineer why is a little dificult for me.
Thanks very much.
Help me any way.
Doug1
cipriano
  I found myself looking at the same topic this morning but was leaning towards capacitors instead for power factor correction. I have 5 soda coolers tons of flouo lights and with the way they go on off at different times and combinations Im guestimating about 60 % wasted energy. Soon as I can get my head wrapped around the cap thoery Im gonna try to transfer that to a Tesla pancake coil and hope that will do the power correction. Im not all that confident in caps. Im still trying to figure why charges would want to seperate in a cap.
scianto
Another scientific toy run as rotoverter, 99% power saving.
An example of big power saving when (idle) running three phase motor of nominal power 5.5 kW (7 hp). This motor needs only 4 W of active power and 5.2 VA of virtual power. It is run from one phase, at 18 V, 0.29 A, capacitor used 55 µF.
The same motor when connected to 400 V three phase grid consumes 400 W. Power saving is 99%.
The motor cannot be loaded more. Almost all the power is used for overcoming the friction.
Based on rotoverter published by Hector Torrez.
http://www.youtube.com/watch?v=EUNrG9Btp_Y
