Buy Nikon Coolpix 4500 DIGITAL CAMERA From Microglobe.co.uk
Started by amsurfer, March 06, 2007, 05:55:05 AM
amsurfer
Visit:  http://www.microglobe.co.uk
Nikon Coolpix 4500 has got 4.0 Effective Megapixels with a maximum resolution of 2,272 x 1,704 pixels for incredible photo quality prints up to 11 x 17 inches.
Nikon Coolpix 4500 Digital Camera 4x Optical Zoom-Nikkor Lens for a focal length range of 38-155mm and sharp, clear images.
Nikon Coolpix 4500 is built with Superior Exposure Metering with Nikon's Matrix meter.
In Nikon Coolpix 4500, 16 Scene Modes automatically adjust controls for great pictures instantly. Simply set the Nikon Coolpix 4500 Digital Camera to one of 16 settings from Portrait to Sunset, including Multiple Exposure.
Nikon Coolpix 4500 Digital Camera got automatic Built-in Pop-up Flash minimizes the effect of red-eye in Nikon Coolpix 4500.
Specifications of Nikon Coolpix 4500 Digital Camera
Type of Camera: Nikon Coolpix 4500 Digital Camera is a digital Camera E4500
Effective Pixels of Nikon Coolpix 4500: 4.0 million
CCD: 1/1.5-inch type (4.13 million total pixels)
Image Size of Nikon Coolpix 4500 Digital Camera: Full 2272(2,272 x 1,704); UXGA 1600(1,600 x 1,200), SXGA 1280(1,280 x 960), XGA 1024(1,024 x 768), VGA 640(640 x 480); 3:2 (2,275 x 1,520) selectable
Lens of Nikon Coolpix 4500 Digital Camera: 4x Zoom-Nikkor; f=7.85-32mm (35mm format equivalent to 38mm-155mm) /f2.6-5.1 with macro; 10 elements in 8 groups
Digital Zoom of Nikon Coolpix 4500 Digital Camera: Up to 4x
Autofocus system of Nikon Coolpix 4500 Digital Camera: Contrast-detect TTL AF: 5-area Multi AF or Spot AF selectable
Focus Modes in Nikon Coolpix 4500: Continuous AF mode (when using LCD monitor), Single AF mode (when not using LCD monitor and/or selectable from shooting menu), Manual Focus (50 positions, focus confirmation image)
Focus Range of Nikon Coolpix 4500: Approx. 11.8 in. to infinity (19.7 in. at widest zoom angle setting), Approx. 3/4 in. to infinity in Macro mode)
Optical Viewfinder: Real-image zoom viewfinder, Frame coverage: 80% (middle range) Diopter adjustment: -2 ~ +2m(-1)
LCD Monitor of Nikon Coolpix 4500 camera: 1.5 in., low-temp. polysilicon TFT (LED-BKL) 110,000-dot; brightness (5 levels) adjustment, Frame coverage: approx. 97%
Storage System of Nikon Coolpix 4500: RGB EXIF 2.2 file (uncompressed TIFF or compressed JPEG). Design rule for camera file system (DCF), Fine: approx. 1/4; Normal: approx. 1/8; Basic: approx. 1/16; uncompressed mode TIFF-RGB Quick Time Motion JPEG (Movie with Audio)
Media used in Nikon Coolpix 4500: Compact Flash(TM) (CF) Card Type I and Type II (compatible with 512MB / 1GB IBM Microdrive(TM)).
Shooting Modes in Nikon Coolpix 4500: Auto, Scene, P (Programmed-Auto), S (Shutter-Priority Auto), A (Aperture-Priority Auto), M (Manual)
Shooting Menu Options in Nikon Coolpix 4500 Digital Camera: Single, Continuous, Ultra-high speed Continuous (approx. 30 fps for 70 QVGA-size images), Movie with audio (35 sec. for QVGA-size images at 15 fps), Scene (Portrait, Party/Indoor, Night Portrait, Beach/Snow, Landscape, Sunset, Night Landscape, Museum, Fireworks Show, Close Up, Copy, Backlight, Sports, Panorama Assist, Dawn/Dusk and Multiple Exposure), Multi-Shot 16 (5 fps; 16 frames in 1/16 size), Image Adjustment (Auto/Normal/More Contrast/Less Contrast/Lighten/Darken), Image Sharpening (Auto/high/Normal/low/off), Saturation Control (-2 - +2, B&W, Sepia), Self-timer (3 or 10 secs, user selectable)
Exposure Metering: 4 mode TTL metering: 1) 256-segment Matrix, 2) Center-Weighted, 3) Spot, 4) AF Spot
Shutter of Nikon Coolpix 4500 : Mechanical and charge-coupled electronic shutter; 8 to 1/2,300 sec., and Bulb (up to 5 min.)
Aperture in Nikon Coolpix 4500 Digital Camera: 7-blade iris diaphragm; 10 steps in 1/3 EV increments
Exposure Control: 1) Programmed Auto with Flexible Program (P), 2) Shutter-Priority Auto (S), 3) Aperture-Priority Auto (A), 4) Manual; Exposure Compensation (M) ( +/- 2 EV in 1/3 EV steps); Auto Exposure Bracketing (5 steps within +/- 2/3 EV)
Exposure Range of Nikon Coolpix 4500: EV -2.2 - +17 (W), EV -0.3 - +18 (T) (ISO 100 equivalent)
Sensitivity (approx.) in Nikon Coolpix 4500 Digital Camera: Auto or Manual (ISO 100, 200, 400, 800 equivalent); can be controlled in any exposure mode
White Balance: 1) Matrix Auto White Balance with TTL control, 2) 5-mode Manual with fine tuning (Daylight/Incandescent/Flourescent/Cloudy/Speedlight), 3) Preset, 4) White Balance Bracketing
Self-timer in Nikon Coolpix 4500 Digital Camera: 10 sec. or 3 sec. duration
Auto OFF Mode: 30 sec.; can also be set manually (1/5/30 min.)
Built-in Speedlight in Nikon Coolpix 4500: Auto pop-up type. Shooting range: approx. 1.6 -9.8 ft. (W), approx. 1.6 - 5.2 ft. (T). Flash Control: Sensor flash system. Flash modes: 1) Auto Flash, 2) Anytime Flash, 3) Slow Sync, 4) Red Eye Reduction with pre-flash, 5) Flash Cancel
External Speedlight of Nikon Coolpix 4500 Digital Camera: Multi-flash sync terminal connects to external Nikon Speedlight SB-80DX/50DX/28DX/28/26/25/24/22s through the Multi-Flash Bracket Unit SK-E900; built-in Speedlight can be canceled when using external Speedlight(s)
Playback Menu Options: 1) 1 frame, 2) Thumbnail (4/9 segments), 3) Slide Show, 4) Enlarged playback (up to 6x); Histogram indication and highlight point display; Focus confirmation indication; Hide and protect attributes can be set to each image
Interface system in Nikon Coolpix 4500: USB 1.1 interface
I/O Terminal: Power input; Audio/Video output (NTSC or PAL selectable); Digital terminal (USB 1.1 / Remote Cord); Sync terminal for external Speedlight
Power Requirements for Nikon Coolpix 4500: One Rechargeable Li-ion Battery EN-EL1 (included), One 6V 2CR5/DL245 disposable lithium battery (optional), AC Adapter (optional)
Battery Life in Nikon Coolpix 4500 Digital Camera: Approx. 100 min.(as measured at room temp 68?F under standard Nikon test conditions: monitor on, zoom adjusted with each shot, flash used in approx. one third of the photographs, image quality set to normal, image size set to 2,272 x 1,704) when using LCD monitor and EN-EL1 battery.
Dimensions (W x H x D) of Nikon Coolpix 4500: 5.1 x 2.9 x 2.0 in. (main body 1.6 in. depth)
Weight of Nikon Coolpix 4500: The Coolpix 4500 weighs approx. 12.7 oz. (without battery and storage media)
Accessories Included with Nikon Coolpix 4500
Lens cap, Neck strap, Audio Video cable, Nikon Coolpix Starter Memory Card 16MB, USB cable UC-E1, Rechargeable Li-ion Battery EN-EL1, Battery Charger MH-53, NikonView 5 (COOLPIX) CD-ROM
NikonView 5 System Requirements for Macintosh: OS: Mac(R) OS 9.0-9.x (only built-in USB ports supported), Mac(R) OS X (10.1.2 or later)Models: Mac(TM), iMac(TM) DV, Power Macintosh(R) G3 (Blue & White), Power Mac(TM) G4 or later, iBook(R), Powerbook(R) G3 or later (only built-in USB ports supported), RAM: 32MB (64MB or more recommended)Hard Disk: 25MB required for installation, with additional amount equivalent to twice the capacity of the camera memory card required when NikonView 5 is runningDisplay: 800 x 600 with thousands of colors (millions of colors recommended)Others: CD-ROM drive required for installation
NikonView 5 System Requirements for PC: OS: Windows(R) 98SE, Windows(R) Me, Windows(R) 2000, Windows(R) XP Home Edition, Windows(R) XP Professional pre-installed modelModels: Only models with built-in USB ports supportedCPU: Pentium(R) 300 MHz or faster RAM: 64MB (128MB or more recommended)Hard disk: 25MB required for installation, with additional amount equivalent to twice the capacity of the camera memory card required when NikonView 5 is runningDisplay: 800 x 600 with High Color (True Color recommended)Others: CD-ROM drive required for installation
Nikon Coolpix 4500 Digital Camera is the best camera for digiscopy. Nikon Coolpix 4500 camera is widely used in microscopy.
In Nikon Coolpix 4500 the focus is internal.
Macro photography is best done by Nikon Coolpix 4500.
You can take your own picture by Nikon Coolpix 4500 as it rotatates.
Majority of digiscopy attachments are made for Nikon Coolpix 4500
For More Information Visit:
http://www.microglobe.co.uk/catalog/product_info.php?pName=nikon-coolpix-4500-digital-camera
