High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
buzneg
I just realized this, this is what the GEET does.
http://www.startech.net/
http://www.plasmaenvironmental.com/
They generate enough energy to power themselves, plus some, tires or mostly anything works.
I gota re-read this stuff, they make Hydrogen by breaking the molecule, or by breaking the atoms??
keithturtle
Okay, mebbe it ain't so gargantuan after all.   But still count me in, and I'm preparing the banking cell casing for several MiniBrutes, to run on demand.
More later.
Turtle
Soli Deo Gloria
snoyl
 my grandfather told me about a guy that had an adapter plate made that fit under his carb on a big block motor.
He would use the 4 barrel carb to get up to speed, then flip a switch that activated a silanoid that switched to a lawnmower carb. my grandfather said he was getting about 70mpg. IH when you mentioned that it brought back the memory, thought id share. BTW here is a patent that I came across low V low I no heat http://www.google.com/patents?id=BxAuAAAAEBAJ&pg=PA3&dq=electrolysis+hydrogen#PPP1,M1  I didnt quite understand there diagram. it seemed a little obscure.
rapttor
Quote from: hkyle on August 03, 2007, 11:20:35 PM
Ohhhh shi% yes please....ummm is enything in there gona freeze juring my um winter months....lol....
Quote from: IronHead on August 03, 2007, 10:32:15 PM
Good ole, Mr. Pantone... yes I've dug into this as well, but had put it on the back burner until the hydrosonic pump & HHO are wrapped up. But I'm with all the other guys, Yes teach... We'll stay after school ...
"Young Jedi you must master the thermocatalytic cracking of a liquid to gaseous state first...ahuummm.
So lead into Experimentation & deliver us From Big Oil.... (about as religeous as I get).
-rapttor
Successfully Perpetually Failing at everything I do...
IronHead
Thats cool . I always wanted to do a Cell with corrugated plates. I have never been able to fine the material or spent the time to produce them myself.
Thanks  "snoy"
