High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
IronHead
BTW  HHO makes a very good SS welder with  practice  :)
"Motorcoach" , Go here  all you need to get started up is at the bottom of the page.
http://www.overunity.com/index.php/topic,2057.900.html
Good Luck
IronHead
keithturtle
Thanks, all fer the MIG TIG tips.   I've been outa the collision repair business fer pert near two decades now, so now most my weldin' is dumb big mild steel, trailer frames and farm stuff, no more HSLA, alloys, etc.
I've had reasonably good luck with the chinese tool store (Harbour Freight).   I might dare to try their TIG.
I ain't big on convertin' tools if'n I can avoid (=afford) it.  With whatever I've spent so far, that TIG will reach <grimace>
@ZFF; check out that chinese watt meter on the cold fusion thread.  Yes, Harbor freight, $30 US.   Works like a champ, but I ain't gonna push the limit with it.
Gots the acrylic slabs & parters cut fer them thar bubblers; as far as the circulation goes, think "undergravel filter" in yer fishbowl.   It's the head levels and backpressure balancing that'll give the turtle fits.   We shall see.
More later.
Turtle
Soli Deo Gloria
snoyl
hey, here is  something i came arross 1934 patent # 2,006,676 water carb. You all probly have seen this but here is the source http://www.keelynet.com/energy/garrett.htm.
   Ron.
ZeroFossilFuel
Tonight I tried my new gas metering device. It worked flawlessly! The modified cell not so flawlessly. Sid was right. MUCH more leak-by current across the bottom when I was forced to cut out the perforated bottom plate. I also had gas coming off both sides of the positive electrodes because there was nothing to insulate the back sides and lots in the middle around the negative. Despite all this, overall efficiency still improved slightly, offset by the gain of closer plate spacing. It also ran noticeably cooler. What I learned:
A) The perforated floor of my plate cavity design did in fact provide some leakage isolation. I highly recommend it.
B) It's important to insulate the back side of the positive plates. Even though both positive plates are at the same potential relative to each other, there is still lots of leakage through the solution to the negative bypassing the neutral plates.
It's full steam ahead now on the next generation cell. It will have neutral plates 1/2" higher than the side walls, edges sealed with adhesive into the side wall grooves and electrolyte level about 1/4" above the side walls. Can't wait to show it off!
Now if I can only find a builder with scrap 4" PVC drain pipe laying around......
ZFF
P.S. Forum email notifications for me lately have been unreliable at best. Anyone else notice a problem?
My public PGP key. Please help support my work. Donate by PayPal
ZeroFossilFuel
Posting in this thread because of the high interest it continues to generate. Found Potassium Hydroxide KOH locally today! Home Depot in the plumbing section for drain openers. It is in liquid form but I'll take what I can get. It's Pequa brand Heavy Duty Drain Opener. 32oz white plastic bottle with red lettering about $6. Hope it works. Cheers!
ZFF
