High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
hartiberlin
Quote from: IronHead on April 24, 2007, 09:16:35 PM
That was the newest Divx 6 codac .
Lets try the trusty old 4.12 it should work fine.
Interesting movie.
How do you get it to burn so slowly ?
Is there also generated some other gas with it ?
Not just HHO ?
One thing:
Please next time only use
300 Kbits/sec datarate at 352x288 resolution.
Almost 1 Mbit/sec is much too much bandwidth
for these small movies.
This saves a lot of bandwidth costs.
Many thanks.
Regards, Stefan.
Blacksmith
Quote from: buzneg on April 24, 2007, 09:44:27 PM
I just realized something I wanna point out. To my knowledge you can't make metal unatractive to magnets, just by heating it up, that only works to demagnetize permanent magnets. No matter what the order of the domains, the iron atom will always attract magnets.
We Blacksmiths heat steel up till it is no longer attracted to a magnet then quench it in oil or water or other. The non-magnetic stage tells us the temp of the metal, very accurate.
IronHead
Sorry about that hartiberlin those were settings for something else, I was in a hurry so the guys here could see the video. I will from now on make sure I check and reset my setting proper. 352x240 at 300kbs
The video has been changed out to these new settings.
I am not sure about 352 x 288 I have never  seen that resolution before.
This is Hydrogen and Oxygen nothing more. This type of hydrogen is called ParaHydrogen .Up until now only  very small amount of this type could be produced ,using a SS coil in water and some low feqs . But as you can see large amounts are poring off  nicely.
TheOne
do you produce enough HHO to feed a car or VUS with your current setup ?
look really good so far nice work!
IronHead
These are just experiments to understand and build the next generation of HHO systems to run cars, generators and such.
Thats why this is all done in such small forms ,at this moment until which time that all these studied systems can be accumulated and integrated into a superior system.
I will release details as I go and understand them . I will not release info that is not complete in its study unless there is someone that is doing the same thing.
It is possible to happen across very dangerous things while in these infant stages . It is well known that  1 cc of water has unimaginable energy stored with in it . If the atoms of hydrogen in some way go critical to the point of collapsing to a photon then "Huston we have a problem". good or bad we still have a problem. So until I fully understand what is going on. I will show my progress here. Then later discuss points of development.
If you were to try and run HHO where the hydrogen was ortho only without gasoline you will burn holes in your pistons  Ask BMW  about that lol. So you would have to ceramic coat the cylinder walls the heads and run forged pistons.
Along with Stainless valves and  ceramic sets .That will cost you more than the car did.
With my new system this will not need to be done on any  engine.
I will revel more as this adventure goes on .BTW  none of what I am doing is  a concept ,  I build it  , it teaches me what to do next.
When I am done I teach you.
Then when you build it you can teach me.
Hence the evolution of all things man made.
