High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
Grumpy
Quote from: IronHead on April 27, 2007, 04:21:35 PM
there will be both types of Hydrogen produced at the say time for those that wish to go that far.
And that is all we need to know!
EDIT: deleted "hydrocarbon fouling crud" - any oils or other hydrocarbons and contaminates must be removed before running the cell.
Hkyle: "voltage divider" - space between plates is resistor - stack is conductor
        -Frank Edwards
IronHead
hkyle
From this did you not understand that I am quite aware that each cell will drop the voltage equal to the number of cells you have....
Quote from: hkyle on April 27, 2007, 03:30:02 PM
As far as the neutral plates are concerned?Surface area is everything when making Hydrogen/Hydroxy. The more plates you have the more surface area you have to make the hydrogen. In a series cell you normally only have 1 Positive plate and 1 Negative plate.
+nnnnnn- this is 8 ss plates with 7 cells. Count your fingers, how many spaces do you have between your fingers..4..
The lowest possible voltage to make hydrogen is 1.24 volts per cell. So in this case you would need a minimum of 7x1.24=8.68 volts.
Ironhead?s example has 19 plates with 18 cells. 36 volts means 2 volts per cell.
Also in a series cell each side of the N plate has a + and ? potential.
This would be +plate +n- +n- +n- +n- -plate
Quote from: IronHead on April 27, 2007, 03:03:38 PM
Quote from: rapttor on April 27, 2007, 02:56:49 PM
I'm waiting for the next question to be posted "why are there so many neutral plates..  ;D
It's great to see that along with a smart bunch of guys out here, you also have good taste in music too...
-raptor
Thanks, So many N plates.  I don't know ,build it and lets find out. :)
Cheap to build from scrap
EVERYONE keep going back to the 3d drawings page 14 . I will post memos there.
It?s easier to be forgiven than it is to get permission....
Grumpy
Then why are you asking about the neutral plates, if you already know?
"Neutral" is a relative term as are "positive" and "negative".
Oh! I see.  We are answering the same question in different ways.
Sorry 'bout that.
        -Frank Edwards
IronHead
<-- **Throws  D-cell batteries at Grumpy an hkyle**
WHACK!!
