High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
keithturtle
Thanks for the tip... I hope to have something up and running by the end of the week.   How does IH get 120 Hz outa line power?  Does a full wave bridge need the bottom half inverted to make it all Positive?  How do  you invert half the signel?   I got bridges, have not yet tried.
Keith
Soli Deo Gloria
RichardDay
Keith,
The full wave AC signal runs at 60Hz which when passes through a full wave rectifier/ bridging diode converts it to 120Hz. It's like this: nunununun becomes nnnnnnn. Check http://en.wikipedia.org/wiki/Diode_bridge for a good explanation
Rich
Walter Hofmann
Hi iron head,
I have to dis agree in regards to piston engine. I have done many runs with hydroxy only in my 5Hp B+S for second up to a few minuts and the only thing what was flying away was the lid from the air filter from a big flashback. I even have to say it pretty much cleaned the piston head from old carbon. I am working on the setup to run my 10Hp /6,000 watt generator with hydroxy only it starts no probleme, but the engine stalls after a few seconds because the cells did not bring enough gas and the engine runs high with the generator attached.
I thought just to give my two cents from my tests not to scare some fellows.
greetings
walt
Quote from: IronHead on April 28, 2007, 02:25:34 PM
Great to hear mramos
Be very careful  running OrthoHydrogen  in a piston engine alone.
Make sure this engine is something you can part with as this type of HHO will burn holes
in the pistons and heads if run with out a control gas or fuel.If you have a CO2 tank (Mig welder) sitting around you can put a little of CO2 in with the HHO and she will burn slower and not destroy your engine.
Good luck
IronHead
RichardDay
When BMW's Hydrogen 7 was being developed they found that it didn't need any treatment to the head, the cylinders or the block. They didn't need any ceramic coating as the combustion temerature was sufficent to avoid corrosion and there were no heat issues. The one problem they found is that gas built up in the crankcase and quite a few engines went bang. The H2 they use comes from heated liquid hydrogen stored on board. Whether this is of the para or ortho variety I'm not sure. Could it be that the faster burning orthohydrogen is what we need to avoid?
IronHead
Quote from: RichardDay on April 30, 2007, 05:11:45 AM
That is Parahydrogen they are burning , Slow burning hydrogen    you fucking guys don't read do you.There is a big damn difference here when your trying to prove what I say is wrong  get you facts together.
BMW had many Hydrogen endeavors
