High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
IronHead
Quote from: Walter Hofmann on April 30, 2007, 04:55:06 AM
Hi iron head,
I have to dis agree in regards to piston engine. I have done many runs with hydroxy only in my 5Hp B+S for second up to a few minuts and the only thing what was flying away was the lid from the air filter from a big flashback. I even have to say it pretty much cleaned the piston head from old carbon. I am working on the setup to run my 10Hp /6,000 watt generator with hydroxy only it starts no probleme, but the engine stalls after a few seconds because the cells did not bring enough gas and the engine runs high with the generator attached.
I thought just to give my two cents from my tests not to scare some fellows.
greetings
walt
Quote from: IronHead on April 28, 2007, 02:25:34 PM
Great to hear mramos
Be very careful  running OrthoHydrogen  in a piston engine alone.
Make sure this engine is something you can part with as this type of HHO will burn holes
in the pistons and heads if run with out a control gas or fuel.If you have a CO2 tank (Mig welder) sitting around you can put a little of CO2 in with the HHO and she will burn slower and not destroy your engine.
Good luck
IronHead
Here again ,trying to tell me I am wrong . I SAID DON"T RUN FOR LONG PERIODS OF TIME !!
not a few min.
Learn how to read before you post against me !!!
Straight orthohydrogen will burn holes in your pistons if run for long periods of time.
Walter if you are producing Parahydrogen as you said in the other post then yes you can run and engine without this problem. Those back flashes and detonation are because of timing. You can easily  bend a valve as well.
IronHead
I dont' know that this is a good idea . I have to rethink this all
Thank you , the few that can read and would like to learn something
I just have,,,  need time
IronHead
Grumpy
Moving forward now...
Cut enough stainless for two cells, ordered some components, have batteries, should be making gas this weekend.
        -Frank Edwards
MarkEngr
Got my plates coming in today or tommorrow. Going to hit fleabay and try and find the rest of what I need.
rapttor
Quote from: Grumpy on April 30, 2007, 09:20:20 AM
I hope you were referring to HHO gas Grumpy...
... sorry I had to, I don't get the opportunity often...  ;D
Successfully Perpetually Failing at everything I do...
