High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
hkyle
no it is not silver filtered....this has 3 carbon filters and one 5 micron...
should be ok.
All the water around here is alkali so that won't be good..lol
If this does not work i will use bottled water..
It?s easier to be forgiven than it is to get permission....
IronHead
yup you will be ok.
I must sleep
Have fun all
hkyle
Well i guess i'm off to buy a nice big quantity of bottled water...spring water...
Like I said earlier there is too much alkali in the water here, even with the osmosis system.
It's just not taking out enough. toooo much junk to make a nice brown scum on top of the water...that was at 12 volts and .78 amps.
But just to say even after 1 hour of rest the cell still read 2 volts...
wooo hooo i made a battary. ;D
Grumpy
Quote from: IronHead on April 30, 2007, 09:50:22 PM
ok , First don't use distiled water .
use spring water like the bottled stuff . I know a bunch of people are going to say don't do that ,since I brought up the Joe thing. Use spring water anyway there are some elements in there I feel are very important . A good container to do this in is Tupperware type  poly. Seems to be a fair insulator. Put the cell in and pour water about 1/4 inch below the top of the neutral plates .
Ok get your 12 volt battery connected up  and connect one positive leg of the stack only .
Take the negative side of you battery wire and attach something that can prob each plate .  Now with  this prob touch each plate from the closest to the Positive for a few seconds , then the next plate  do this till you hit the center plate of the cell stack, the negative leg.stop
Once you hit center stop , put the positive on the other end of the cell stack and do the same ,one plate at a time till you hit the center again.
This sounds crazy to some . I cant explain why this works it just does , Molecules or some such.
When done with that , connect both positive legs and you negative the way it is shown on page 14. Stay with 12 vdc  let the stack run for about 20 min. keep and eye on heat don't go above 150F.Ok stop after 20min let the thing cool to room temp and hook it up again , run it until you see the water get thick like very high surface tension . Where the bubbles really start to grow good size before they break . now your cell is charged.
You only have to do plate conditioning once .
There is a much more advanced version of this
but we don't need to do it in this cell stack.
Damn , I should change my name to HHO Alchemist .
Its very different when you read then when you just do it .
Even I thought to my self this looks crazy.  this IronHead
guy is off his flippin rocker.
Built it
It Works
IronHead
Read it again
I recall saying that this was not your standard starter cell.  (but I did not expect this)  I will scrounge for stuff to complete before weekend, but weekend is the sure thing.  Working 12-hours days so I can have time this weekend to complete this.  Me arse is sucking wind...
Anyway, I mentioned before that the positive is split and there is a torsion field setup with this cell.  By taking the ground to each plate, you are setting up a gradient diverging at the ground plate.  The gradient is the torsion field, the divergence is the electric field.
Dare I use the term "orgone accumulator".  I would think that you could use circular rings as well as plates - like a Joe Cell does and I will try this with stainless sheet curled around to make rings.  Some that work with the Joe Cell have equated HHO to being "Helionon" - an element identified by Walter Russell as being the opposite of hydrogen and burning by implosion rather than explosion.  Russell ideintified many elements before they were actually discovered - many of these are smaller than Hydrogen.  Orgone / torsion fields are known to be mentally manipulable, hence the sensitivity of the Joe Cell to people's moods and thoughts.
I think aluminum reflects torsion fields - copper conducts them.
Got to go scrounge now...
        -Frank Edwards
rapttor
Well, finished cutting the plates last night... 2X2" & 3X2" for the connection plates, with extras for experimentation later.One thing I didn't take into account, Peel the Friggin plastic OFF FIRST!! Now I've got 20+ postage stamp sized pieces to pick & pick at trying to get them off(yeah, about as fun as watching Gnat's F*%K).
Cut up some acrylic last night and got the body of the Cell completed... I forgot how much it hurts to have a chip of flying plastic get stuck in your eye... IN YOUR EYE... what happens not 15minutes later while removing the burrs, IN THE OTHER EYE!!(a hopeless zero, I am ... I know).
I kept working, plastic is a joke to a steel splinter that has to be removed by having your cornea scraped... anyway, I'll have it together & ready tonight, I found something Perfect for a plate "separator bracket", and I just happen to have hundred of these at work just taking up space!
I'll post picture progress later on today, after suppah time.
-raptor
"If it doesn't fit.... hit it with a hammer...If It Still Doesn't Fit, .... Get a Bigger HAMMER!"
Successfully Perpetually Failing at everything I do...
