High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
wattsup
Well I tried my titanium +8n-8n+ cell with 12 and 24 volts and no go, maybe just a fizzle on the neg plate when I added a pinch of salt. I know but the room was well ventilated. 16 neutral plates may be a bit too much. My titanium is meshed, not solid plate. I will try this at +2n-2n+ and see what happens.
I too am wondering about the minimum water characteristics and also if there is anything else we have to add to the water.
IronHead
Seems like your build is going well.
Sorry guys , I have sustained some injuries while experimenting on the injector stuff.
My hands and arms are wrapped up . Very hard to type.
I will be checking in the best I can .
You will notice on pg 14  there are slots in the side panels of the cell , this is to seal the plates off from voltage leaks side to side.
Also the pic of the generator is an RF generator not a pulse gen.
As far a using KOH in an engine, it will be condensed in the bubbler and be returned to the cell or holding tank. The KOH will not  go into the engine. This is using a circulatory water bubble system , cool the KOH and it is still KOH.  Most all other additives will gas and feed into the engine and many are very dangerous as they go through this transmutation process .KOH  does not gas or transmute  to new materials .
IronHead
My pain is 12 broken bones in my hands and arms . This was a pretty bad deal and very unexpected.
In the pic the setting is 1000x . These are MHz I am dealing in.And GHz on the funnel , but we will get into that.
But thanks for the reply
IronHead
I'm not young. I had an explosion box come apart very quickly lets say. I was standing infront of the box.
This cell should be open on top and on bottom to start out and sealed on the sides.This is clear on pg 14 and the drawing. " top and bottom to be left open"
PG 36  I also edited my post in green about KOH
This is still HHO 101  many of you have just completed your cell or are rebuilding  ,so its all good.
keithturtle
Sorry to hear about the blast.  Been there, twice, fellow phoenix.
You're in my prayers.
Built the second cell, just like the first, only with PC, no OH for this one.
My initial testing was done in distilled water; misunderstood that part.  Still, it received a small charge.   Testing with spring water tomorrow.
Note on spring water- I have access to a natural spring with very little iron, in addition to several different well sources with differing levels of iron before softening.  I'll run some aeration tests to try and precipitate out the iron, possibly a small charge plate as well.  Bought a case of widemouth mason jars to put fittings in the lids... it promises to be an interesting week ahead (only at work two days <grin>)
Keith
Soli Deo Gloria
