High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
keithturtle
About that vacuum pump;
I have one of these sitting on the shelf
http://www.surpluscenter.com/item.asp?UID=2007060819394962&item=16-1139&catname=electric
Haven't hooked it up yet but it'll probably do the job.
Depending on how much negative pressure is needed, a ram air venturi in the air intake may work.  The comment earlier about manifold vacuum as a function of throttle plate position is important... as long as the engine is running, there is vacuum available in the air snout.. and the faster, the greater.
Keith
Soli Deo Gloria
hartiberlin
Hi All,
really please watch these videos form Roy Mcallister and Steve Harris:
http://video.google.de/videosearch?q=Hydrogen+Fuel+Car+and+MultiFuel&so=0
They are really very good !
The question still is, how do we produce the Terpine cheaply via
converting woodgas and destillation ?
How does this exactly work ?
Roy Mcallister mentions, when he drives in his car, that he uses Terpine in his
car helped with a bit of hydrogen.
If Terpine can be cheaply selfmade from destillation
of woodgas or biomass destillation, this would be ideal to store
the fuel as a liquid Terpine..
Then you don?t have the problems to directly drive via woodgas
and fiddle around before start to get the wood burning...
Regards, Stefan.
hartiberlin
Especially this video is very important,
cause he shows an actual ride in a homemade "terpine"
fueled car with hydrogen boost.
http://video.google.de/videoplay?docid=4463667203960833886
Can all be selfmade !
So how do we produce this homemade fuel Terpine" the easiest way ?
The car has a 700 miles range !
Incrediable !
Regards, Stefan.
hartiberlin
Something simular  to this,
but without burning the gases, just to condense them to Methanol or
Terpine ?
http://www.youtube.com/watch?v=OYA-Er2zmbE
How good does the condensation process work and
how much fluid fuel could you get out of it when using
such a pepsi can full of sawdust?
Regards, Stefan.
popeye68
Hi IronHead ,
two questions;
How much vacuum (approx.) on a cell to have any effect ,
i was thinking on first using an old vacuum-cleaner blower.
Using the same diameter tubing to the cell , rebuild the output
side a little. Just to see the difference with or without...
Would the plastic blower create static discharge you think :o?
You spoke of learning us to trick the  O2-sensor , in the Magdrive video's
this guy say's the computer is adjusting the fuel-injectors leaner automatictly.
Does it depents on the type of ecu?
thanks
