High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
hartiberlin
Quote from: Moab on March 08, 2007, 06:56:11 PM
Wonderful!
Here is a Fullwave bridge @16 amps in cold water. I have two 312 stainless cupps for conductors. 4'' 3 1/2'' This makes HHO until the water is over 170 F. After that all you get is steam. Now at about 150 F the amprage drops to about 5-7 amps. this is the sweet spot for me so far. This is not pulsed.     Moab
Oh yeah. If you guys from the shop stop by Overynity.com.. Ah,, That is not your coffee pot. It' an incredible simulation. And if your coffee taist funny in the AM. I know nothing about it!
So how much electrical power is going into it ?
110 Volts AC /60 Hz rectified with Full wave rectifier and then fed onto the tubes
and it draws 16 amps ?
For around 100 Volts @16 amps= 1600 Watts this is very low HHO gas output !
Moab
Quote from: h20power on March 08, 2007, 07:06:18 PM
;D Now we are getting into the new way that a lot of people are starting to understand. I designed a new cell just for this purpose. Using a voltage intensifier circut is my next planed cell driver, for it and it alone is hooked up to the electrolyzer. The new cell is designed to take full advantage of this no current, high voltage concept. Voltage work theory by Stanley Myers is what I have gotten into now. We think we have figured it all out. Zigouras racing has it working just fine they say. As soon as I get the electronics built I will put Joe cell and Myer's tied together with vacuum lines, the Joe cell has to come first for it is electronicly connected, and the Myers cell is totally isolated, as it should be. I will later try to market the Myer's type cell since it is way more cost effective for me to make than a good Joe Cell. Wish me luck :D.
Okay!! Good luck! These pattons are still active. So until the meyers family drops the rights to it, youll have a hard time marketing it.
Moab
Quote from: hartiberlin on March 08, 2007, 07:28:35 PM
Wonderful!
I agree, but this is COLD water. amprage drops to about 7 amps 700 watts, And gas prodiction climbs at 150F you would never get that "small HHO output" from 12v system at the same wattage at any temp. And we havnt started pulsing or fliping polaity yet. I made no clames of massive gas production. I only posted it to show the effect at a given HZ/Voltage. ::) I would like to see 5 LPM, This i think would be worthwhile as a fuel supplement.
IronHead
Again I would like to say. I am not to sure what Myers was doing  ,he was playing with laser interaction with electron force agitation and other high tech stuff.
As far as Volts go as I post in the first post its 90VDC on this one you see in the video. Current is much more complex of and answer. You have to understand this thing is like a capacitor and it charges like one.So we might start out one day at 30 amps and drop to 0.5 amps at 150F and the next day we might start at 20 amps and down to 0.2 amps . The cell when running in the video at 150F intermittent runs to keep stable was 0.2 if i remember correctly. The next time I fire it up it will be different .
Also ,I build for myself out of need not for the market or scientific research.
The truth is for a large part of my life I did not give a damn about the rest of the world.
But that has changed. There are many people out there that are willing to make a change in the world . This I have learned from this forum.
I will post some nice big bangs to show HHO production and as soon as I get a hold of a friend that has a gas analysis system  and the knowledge to help me give you the specs you all seem to need.
(we already did this a few years back ,but will do it again for you guys)
hartiberlin
@Moab,
your system is a completely different one than the onefrom IronHead.
Did you see the videos of IronHead yet on Youtube from the above links ?
IronHead?s system produces so much more gas, that it is increadible,
if it is really done only with 90 Volts DC and 0.2 Amps= 18 Watts ?
If this gas is really HHO ( oxyhydrogen ) and not just steam or CO or CO2
(maybe because of his baking soda ?) ,
then it is really an amazing production rate !
IronHead, maybe you just can put via a hose and a bubbler your device
under test again and light a few bubbles coming from the bubbler water
and show the Voltage on  voltmeter and the amps on an ampmeter.
Did you also use any special pulsing for it ?
Many thanks.
