High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
IronHead
Looks like the world is taking notice. My YouTube page and it videos of HHO were in the top 5 listings of " Most Discussed ) - Autos & Vehicles ". It's  good to see the interest.
http://www.youtube.com/SGiHunter
Everybody Build It!
IronHead
IronHead
The Coffee Pot view of a cell 4"x3"x2"
36VDC at 12 amps
IronHead
CoffeePot cell hot steaming bang.
watch frame by frame if you can.
Sorry still no sound
Video Attached
IronHead
Reading back through these post might explain the spark. But I have had sparks pop a cell. Just depends on the timing and the type of spark.
"Hit" your cell with ?
I don't use 12 VDC  it does not work for me.
Try 36 volts with KOH , add milligrams at a time and wire your plates like this +nnn-nnn+ n = neutral = no connection
Also grind your plates in the vertical  to make them as rough as you can.
Horizontal seem to make the bubbles stick longer.
hartiberlin
Quote from: IronHead on April 09, 2007, 04:33:43 PM
Hi IronHead,
many thanks for the infos.
So you are using 3 neutral plates( not connected) between the plus and minus pole plates ?
What are these "spacers" between your plates ?
Are these just nylon washers or magnets ?
What is the exact setup with your rod type cell ?
Is this a Nitronic steel 50 rod wound around with some wire ?
What wire wound around it and how is it isolated from the rod ?
Did you use also there just 36 Volts DC or did you pulse
the cell ?
Many thanks.
Which cell gives more oxyhydrogen at the same power input ?
Regards, Stefan.
