High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
hkyle
Add more voltage my friend....
ohh and keep the water level below the top of the cell. You have voltage leak at the top of the cell, the voltage is going above the plates thats why you have more activity on the center electrode. the voltage is not going through the N plates due to lack of voltage.....
Great build.
It?s easier to be forgiven than it is to get permission....
IronHead
Also reduce the size of the container the cell is in and go to 24 volts and then 36 .
Try rain water or spring water . Distilled water is dead water.
$um1
Has anyone tried pumping ionized air into your cell. In my studies this increases gas output. IR lasers on the cell also increase production. Why does everyone use KOH for an electrolyte? I use citric acid instead It doesn't turn the water muddy. Instead it looks like flat Mt Dew and seems to work fine.
IronHead
I have never tried citric acid . But I do use IR in one cell.
I encourage people that have replicated the cell with good outcome to experiment  with there own Ideas at this point .
The replication  is done now.  Experiment , jump plats, try citric acid, pulse,ionizing chamber , IR , magnetic influence  . Some of you have the correct build with free floating plates that will resonate nicely other do not. Continue now to build onto this Cell in you own way . This is the way it will become something of use . Share your ideas now that we have come this far.
I will continue to show more of the techniques I use in this type of Cell and what it has evolved to. You have a very flexible Cell if you built it according to the specs. This is the resign why I have been so hard on people that come in here trying to change things . This is a replication! Now it is a flexible low cost experimental Cell Stack .
Lets see what you guys that have done the replication can do now.
IronHead
dlwammo
Thanks for all your info, I'm going to try and round up the parts to get a cell going.
@IH
I just wanted to ask you if the sides of each plate need to be totally sealed?
If a small gap is OK, what is too wide?
Dan
Don't mess with old farts... age and treachery will always overcome youth and skill!
