High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
IronHead
One of the problems I find with this type of test on these Cells , is pressure.
Even the smallest amount of pressure greatly reduces the output of the Cell.
Those small plastic float type flow meters work well.
yikes
Wanna see a good looking spark plug?  In use for over a year in a daily driver, run on Hydro boost for over a month http://i180.photobucket.com/albums/x171/mryikes/2007_0715sparkplug0001.jpg
I changed to a 1" tube (3/4" angles).  I get water drops inside the tube at idle.  At 2k rpm I can watch the vapor being sucked in.
BTW, the 3m window weld stuff works well.  Seals the cells, turns to a hard rubber, holds up to heat, doesn't flake off or cause scum in the solution.  Doesn't seem to be affected by naoh.  Comes out of the tube thick, like caulking.  Kinda messy though.  Since it's black when you get it on your hands and rub your hair, it gets rid of the grey.
IronHead
Good pic , HHO does keep her clean along with steaming the inside of the engine.
Thanks yikes
rapttor
Yikes... is that an MR2 or Fiero?
That is by far one of the cleanest plugs I have ever seen that has done a year's time in a D.D.
Nice work.
-rapttor
Successfully Perpetually Failing at everything I do...
IronHead
Some footage of Stan Meyer's first HHO dune buggy. Just thought I put out there.
http://www.youtube.com/watch?v=m8F44mrrlbA
This a led in
gearing up to show some new videos never before seen. Will HHO run a car 100%?
IronHead
